Opinion On 25 Tantrum >
Old 11-12-2005 | 11:35 PM
  #71
Default Re: Opinion On 25 Tantrum
Originally Posted by JUPITER PULSARE
Hey Mike, if I remember correctly (??), we were swinging a Bravo one 26, Lab finishing will give you an extra 2 mph at wot. By the way, Thunder Rick is correct. The boat will run faster in the salt water (more bouyancy) and at sea level (more oxygen to feed those hungry cylinders). Pat could give you better feedback on prop choice....he's got more seat time in that boat than anyone. The reality of a 25' Tantrum is that when the water gets snotty, that boat will crush it's way through and leave other similar sized boats in it's wake!!
Jupiter Pulsare,
The boat had a 26 on it when I purchased it. 74 was my best. I purchased a 28 had Mercury Racing lab it and they reduced the outer dia from 15 1/4 to 14 3/4. It seemed to reduce some of my porpoising and chine walking and I seen about 1 more mph. Rpms are hitting 5250 with the 28 Bravo 1.
Thanks for the feed back.
Mike
Active Mike is offline
Old 11-13-2005 | 11:27 AM
  #72
Originally Posted by Active Mike
Jupiter Pulsare,
Mike
Hey, Mike you may want to have the 26 Lab finished, Have them put some more cup in the 26 if you're hitting the rev limiters...sometimes, trying to swing too large a diameter prop or too much cup will induce chine walking in a single screw boat. Our smaller, lighter, outboard powered boats are more prone to that than the I/O offshore boats. Also, keeping everything in the boat centered and low will help alleviate chinewalking. When your flying along at WOT the boat wants to ride up on the very bottom of the keel, at the same time the torque from the prop is trying to tip the boat to one side....it's a balancing act that can be countered partially in the way you steer and trim the boat, too much trim and the boat will dance like crazy, tuck the nose down a little, get back on the throttle, and maybe drop the tab on the side that keeps falling off (just a little) (if you have tabs??) and you should see improvement.....If you think it's hard in a deep V boat...try it with a padded keel....at over 72 mph I get white knuckled in my 21' Checkmate Pulsare/merc 225 Xri just trying to keep in on the pad.....makes for fun, challenging driving!!!! Steve E
JUPITER PULSARE is offline
Old 11-14-2005 | 11:26 PM
  #73
Jupiter Pulsar,
When I run the 26 which I think was lab I have more chine walking and more porpoising. RPM's are running right at 5300. Do you think that I should go back to the 26 from the 28 that is on it and do some more work on it? I realize that it's called the prop game which I will continue doing if I need to. My biggest issue is trying to reduce the porpoising of the boat if it is possible thur the prop.
Thanks,
Mike
Old 11-15-2005 | 01:56 PM
  #74
Hey Mike, sometimes finding a good prop will help in handling and reduce chine walking. Also x-dimension plays a big role..if your drive is buried deep in the water the boat will want to chine walk; you could try an imco shorty or xr drive (which I think is shorter, Pat would know as I've not been involved with up to date Merc info since getting out of offshore boats). You may also want to try a 3 blade prop..I would reccommend a Merc Tempest plus 27. Great prop for top end numbers. It's a never ending battle of trial and error when dialing in a boat. Good luck!! SteveE
Old 11-19-2005 | 12:42 AM
  #75
Steve,
Thanks for the input. I will continue with the prop game to see where It will take me and go from there.
Thanks again for the help.
Mike
Old 01-18-2007 | 05:07 PM
  #76
Tantrum's Avatar
Ttt
Tantrum is offline
Old 01-18-2007 | 05:38 PM
  #77
camptappakeg69's Avatar
what's with all the 25 threads comin back, some one buyin
camptappakeg69 is offline
Old 01-18-2007 | 07:18 PM
  #78
Tantrum's Avatar
I had a call from a guy in Long Island that is looking for a 25. I told him to come over here and talk to you hooligans for the straight poop.
Anyone want to start a new list is 25's available
Tantrum is offline
Old 01-18-2007 | 08:15 PM
  #79
Nothin but postive things from me but only got about 6hrs on it before I had to winterize............c'mon spring
Old 01-18-2007 | 11:12 PM
  #80
R Addiction's Avatar
AT Cult Member #3
Heard that Camp.....is it April yet?
R Addiction is offline
