Pat, need a direction on a couple things. >
Old 10-15-2004 | 06:47 PM
Sydwayz's Avatar
Forum Regulator
Default Pat, need a direction on a couple things.
Pat,
First, I need two identical drain plugs as you have on mine and Rich's boat, the chrome plugs with chrome fittings. I am going to install them behind the step. Who makes them? Do you have any in stock?
Second, I broke one of my switches on the dash. I need a replacement. Who makes them? Do you have any in stock?
Third, I am adding a whomping stereo to the boat, and I need want to replicate the little 5 ckt breaker under the rear seat for amps and such. Do you have these in stock in different Amp ratings? If not, who makes them?
I have checkbook in hand and a stamped envelop ready to go. Please let me know. I think I am getting straight with the Water Actuator Valve. There are two in the country, and I think one has my name on it already. At least I hope.
Sydwayz is offline
Old 10-16-2004 | 07:07 PM
ActiveThunder's Avatar
Default Re: Pat, need a direction on a couple things.
Brian, I'm making a note. We have the plugs and switches on the shelf. What/where is the breaker? Describe it a little.
Thanks, Pat.
ActiveThunder is offline
Old 10-16-2004 | 08:04 PM
Sydwayz's Avatar
Forum Regulator
There is a circuit breaker under the rear seat on the forward wall of the compartment, with 5 circuits, one for each of the 4 fluid pumps, and one for the hatch ram, (if memory serves). I am going to replicate this setup for my 4 amplifiers, so the exact same piece would work, as long as I can come up with the right circuit breaker amperages. Two CBs need to be 75A. Two CBs need to be 105A. One CB would be empty. Thanks for the quick response.
I broke one of the dash switches while trouble shooting behind the dash one day. I need to replace that one, (which I rotated to the Mufflers slot), since I don't have Mufflers. I am going to use that switch for the Neon lights.
Sydwayz is offline
Old 10-17-2004 | 08:56 AM
excursion's Avatar
Pat ,
This is James in Va. and I also need to get one of the white switchs on the dash, I need the hatch switch,( momentary/off/momentary ) Tell me how much and I will get you a check out, with my address.
And I also need the the old style AT logo that went up on the side of the boat above the foot step at the front bolsters, I have the correct color of vinyl, can I ship it to you and your guy cut them out on send back, the edges are starting to peel a little.
James
804-539-3114
excursion is offline
Old 10-18-2004 | 10:31 AM
excursion's Avatar
Ttt
Old 10-21-2004 | 08:11 PM
Sydwayz's Avatar
Forum Regulator
Pat, TTT please! I responded about the CBs!
Sydwayz is offline
Old 10-23-2004 | 07:20 AM
Brian,
We buy them from Pacer Marine which is 954-462-0902. We buy as we go so we don't stock them. The part number is EL1-1-"70" or whatever amperage you require. The highest I see listed is 100. They also sell the blank panels.
Hope that helps, Pat.
Old 10-25-2004 | 07:53 AM
excursion's Avatar
Hey Pat!! what about the switch's and the vinyl lettering I needed? Is it possible to still get these?
Thanks James
JJONES
Prop Talk
7
04-18-2006 07:13 PM
epeek
Fountain
22
01-22-2005 11:10 AM
flylevel
04-03-2003 11:55 AM
MIKEHTMSR24
3
03-23-2003 08:48 PM
HOTROD2
20
02-10-2003 07:13 PM
