-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Winter Projects Complete (https://www.offshoreonly.com/forums/active-thunder/99614-winter-projects-complete.html)
BobbyB 03-31-2005 08:58 PM
Re: Winter Projects Complete
Looks good James!
excursion 03-31-2005 09:24 PM
3 Attachment(s)
Thanks for the compliments, Yes Pat it is bolted to the stringer and is very secure. Perfect size to sit at and watch TV or play cards on. Easy to store, I put the table top under the v-berth cushion and the pole behind the couch compartment.
excursion 03-31-2005 09:25 PM
1 Attachment(s)
Still need too clean up those welds a little.
But when it is not up this is all you have to look at.
docmanrich37 04-01-2005 06:39 AM
James it looks good.I might hire you to build me one but i want the settee built to.so hook me up.stereo done and it sounds good but you might have to tune it if you would.
excursion 04-01-2005 06:57 AM
No problem Rich, get any more testing done?
Talked with Mark, going too go up your way on Sunday and test props. What time are you coming back?
docmanrich37 04-01-2005 07:40 AM
Tested last nite at 5:00 and again same speeds on flat water.so i guess i'll just burn the gas out this weekend.not sure what time we're coming back but i'll call you on sunday on our way back to let you know if we can hook up.
excursion 04-03-2005 09:04 PM
Tested today, top speed with Bravo 1 30's / 87.4 mph
55 degree's , 3/4 tank of gas , two people, 1 foot chop.
BillR 04-06-2005 02:05 PM
James,
Where did you get the SS braided hose & hose clamps that goes from thermostat to upper header port?
I need exactly the same thing. Part #'s will also help.
Boat looks great! I will finish mine this weekend and maybe splash Sunday WX permitting.
Thanks!!
excursion 04-06-2005 04:17 PM
That braided line was factory on the HP series in 99, so I dont know who makes it for Merc. maybe check in the Jegs book.
docmanrich37 04-07-2005 05:46 PM
3 Attachment(s)
Did a little winter project too.a little paint and a little clear.what a shine.
