Go Back  Offshoreonly.com > Owners Forum > Advantage
Shorty drive on 27 Victory >
Old 04-08-2012 | 09:31 PM
Originally Posted by TROR
Did you get that boat out yet snapmorgan? Curious if the -2 helped & if you were able to p/u some rpms for a bigger prop.
I picked up about 400 rpm, but not enough to have to prop up.
snapmorgan is offline
Old 04-09-2012 | 12:31 AM
Good to hear you had some nice results. I would think with 575hp you should be running a tad faster though. What are your slip numbers on the top end? What rpm are you spinning and what's the rev limiter set at?
-Tom
ToMorrow44 is offline
Old 04-09-2012 | 05:54 PM
Haven't put the numbers into a slip calculator yet. Running 5500 rpm with the B1 and the Hydromotive, 5800 rpm with the labbed 24B1. Engine just off dyno, made 567hp. Rev limit set at 6300. Mine is the bowrider version. It is a little heavier and more bow heavy. Plus it is full of stuff. I need to take an inventory and remove about half of the crap in it that we don't ever use. Engine makes max torque at 4000 and max hp at 5200. I have a 25 3blade that I am going to try. Might be able to pull a 5 blade 23 or 24. have you tried anything like that?
Old 04-09-2012 | 06:38 PM
Default shorty
i have a 27 an i put a 2in shorty an didn help ...it hits a wall at85 an jus cant get past....660hp an 28 stock bravo ran 78 to 80 but didn go much faster with 888hp
American Thunder is offline
Old 04-09-2012 | 08:10 PM
Thats about 20% slip for the stock 24 and the hydro, 25% slip for the 24 lab. A little high, but not uncommon for the 27s. I forgot you have an open bow, that would account for ~5mph slower. I have tried the Hydro P-5X and Maximus with good results, gets up on plane extremely well with awesome midrange, I just had it overpropped at the time so it was only spinning 5300-5400. Still testing!
I have run my boat with 620hp with both a standard and -2 shorty and now 800hp with standard and -2, each time the -2 was several mph faster and handled better. Also, where are you getting your speed numbers? I maxed out at 73-74 with 620, now running 85-86 with 800hp...there must be something off on your boat...
Old 04-09-2012 | 10:27 PM
ROB FREEMAN's Avatar
it must have one flat curve to have max rpm hp of 5200 and a rev limiter set at 6200 . i dont think id want mine set there acording to youre info . id prop for max hp
ROB FREEMAN is offline
Old 04-09-2012 | 11:06 PM
Toms rig hauls for sure, I hope to bum a ride in it in the next week.
When you say you made 567 on the dyno what exhaust and accessories were you running on that dyno?
Uncle Dave
Uncle Dave is offline
Old 04-10-2012 | 11:16 PM
turning all accessories and raw water pump. Had a set of Dynatech headers with EGT sensors installed. I am running Imco power flow's in the boat.
Old 04-10-2012 | 11:25 PM
There is a 25 Hydromotive in the swap shop right now, what do you think? On the 24's the Hydromotive wanted to blow out pretty bad taking off. The Bravo 1 had much better bite, but i could blow it loose if I wanted.
Old 04-10-2012 | 11:59 PM
powerflows or powerflow pluses?
UD
