Windshields fo 26' 1996 AO NSX
I used lexon plexiglass because its stronger and i got it at at place near my house. I traced it out and cut it with a jig saw and smoothed it out with a sander. Not sure where you can get it but im sure you can either find a place near your area or get it on the internet.
Dave.
Dave.
Thanks. BS. I'll try that. I just replaced starboard side so I'll have a pattern to trace. When I bought the boat it came with 2 replacements. Is port the same as starboard? Are the holes drilled in the same spots?
No there probally not the same. Match the holes up with your other windshield. Drill about 6 holes 2 on each side amd 2 on the front. Put the windshield on with some one holding it and drill the other holes with the windshield on the boat. Make sure you use lexon. The other plexiglass wont bend as easy.
jrodnj
01-01-2007 09:26 PM
