Go Back  Offshoreonly.com > Owners Forum > American Offshore
Think im ready for a 31 >
Old 07-29-2008 | 02:55 PM
Ran-Dom 32's Avatar
she will blast a nice roost
Ran-Dom 32 is offline
Old 07-29-2008 | 05:15 PM
actually, with the x that is on it now.. he would be better to get a 2" shorty and use a box... I think he might like the stellings so that he can adjust from there up or down 1" to help it out some more... i think if he gets aggressive he can get 2" shorties and use the -1" of a stellings with to get the most mph... might have to use a 5 blade though to make it work... but i think that would be the best starting point...
Don
chromecat is offline
Old 07-29-2008 | 06:34 PM
Rottiguy's Avatar
I was thinking imco boxes 12 back and 3 up with stock lowers for now maybe shorties later if needed
Rottiguy is offline
Old 07-29-2008 | 07:09 PM
DirtyMoney's Avatar
Try here I am learning too
http://www.offshoreonly.com/forums/s...d.php?t=192034
DirtyMoney is offline
Old 07-29-2008 | 08:44 PM
It's a matter of preference...
when you go with the 3" up and 12 " back box, you get to raise your x up and keep using the same drives however, hou have to completely re-rig the engine compartment as the engines have to go up 3"'s and also back some measure of the transom angle.
If you use the standard boxes and use shorty drives you just have to lift the engines off the transom assymblies so that you can replace them with the new inner plates and engines stay where they are in the boat. you have to spend money on the shorty drives, but much less labor involved in the boat.
bonus to changing drives is you can change gear ratio with an imco lower. bonus to the ao's most boats don't allow enough engine clearance to raise the engine 3" , the AO has plenty of room to come up that much or more(unless you plan on putting blowers back on and no scoops)
Old 07-29-2008 | 09:13 PM
Rottiguy's Avatar
I think I need a Staples Easy Button, and a magic elf to figure this out for me. All I wanna do is 125!
Rottiguy is offline
Old 07-30-2008 | 06:19 AM
well hell 125....
that is easy...
Don
Old 07-31-2008 | 07:45 AM
Rottiguy's Avatar
boxes blowers and lowers!
Rottiguy is offline
Old 07-31-2008 | 06:07 PM
then why stop at 125.....
satisfactionII
Grand Lake/LOTO/E-Dock
0
09-08-2007 02:21 PM
Superbabi
Superboat
76
05-14-2007 08:12 AM
Need-the-Speed
Baja
4
10-26-2004 09:51 AM
Dano
Sonic
13
03-23-2004 03:17 PM
