Go Back  Offshoreonly.com > Owners Forum > American Offshore
31 AO setup questions >
Old 07-22-2010 | 06:55 PM
Default 31 AO setup questions
just got a 31 american with 500's.. wondering if extension boxes work and if so nuetral or -1 or -2 s? with standard or shortie lowers? looking to get to 115 mph.. how much power? will 650's do it?
Baja555 is offline
Old 07-23-2010 | 08:57 AM
what year boat? probably get there with boxes and blowers on top of the 500's.... what drive,what x?????
Don
chromecat is offline
Old 07-23-2010 | 10:01 AM
tssteph's Avatar
Which boat did you get? Pics?
tssteph is offline
Old 07-23-2010 | 12:32 PM
Wich boat did you buy? I just bought one with the same setup,
I have a pair of stelling boxes. The boxes have lifted my X up to 1" above the bottom of my sponsons.
You will need more than 700's to go that fast depending on the year of your boat.
Let see some pic's......
phil_p999 is offline
Old 07-23-2010 | 03:04 PM
95 Boat was in NJ bravo's propshafts are even with the bottom I have a -1 shortie will get another one if they will work..
Baja555 is offline
Old 07-23-2010 | 03:14 PM
tssteph's Avatar
Even with the bottom with no boxes is as good as it gets. With stock lowers i have not seen one be even with the bottom. Maybe some have different X's thought. Most people use a -2 lower to get very close to even with the bottom.
tssteph is offline
Old 07-23-2010 | 03:22 PM
yeah, its even with the bottom standard lowers
Baja555 is offline
Old 07-24-2010 | 08:15 PM
you put up 1 maybe up 2 with boxes and blowers on the 500's ... get it to 650-700 hp.. work with the props ... you should get there ...
Don
Old 07-24-2010 | 08:38 PM
Agree. Perhaps built or in-service modified with the transom mount relocated. In any event, my calculations show when using a 12" set-back (IMCO neutral boxes) that you gain +1 inch. So, if Baja555 where to install neutral boxes and his -1inch shortie lowers, bada bing he is at 0 to the hull. Beyond that, get with a darn good prop professional (Brett at BBlades) and it's all with the prop set-up.
Adding boxes to your 31 AO is one of the best add-on's that you can do. Speed aside, the handling characteristics are well worth the cost.
ROTAX454 is offline
Old 07-24-2010 | 08:46 PM
Phil, Speaking of pics, where are some of your new ride?
ROTAX454 is offline
