-   Apache (https://www.offshoreonly.com/forums/apache-55/)
-   -   I LOVE this GD boat! (https://www.offshoreonly.com/forums/apache/133454-i-love-gd-boat.html)
birdog 08-08-2006 01:28 PM
Re: I LOVE this GD boat!
Originally Posted by Jayl13
Mark, Ill buy your 41 apache for 4000 bucks! SIGN ME UP, Ill have twins!
You better drive faster than I do !!! :D :D
Marks is one of my Favorites for sure !!!!!
Jayl13 08-08-2006 02:00 PM
yeah but it wont be a twin of your boat, I need two of these things bubba!
LOL
Hows it going anyway?
birdog 08-08-2006 02:11 PM
Going good...Gun is running pretty good....still dialing things in.
You getting things worked out ?
el indio 08-08-2006 04:20 PM
insurance is 4000.00 dollars.with blowers. pullys never came up.TOO MUCH WORK.............mark..........
Jayl13 08-09-2006 09:06 AM
Slowly getting things together. I think I am going to start the painting process shortly and get my baby princess a face lift while the few parts are out being worked on.
Get something moving right?
el indio 08-10-2006 07:05 PM
1 Attachment(s)
try this...........total from dashboard back.............lot of work..........m.m......
OldSchool 05-25-2007 09:31 AM
Still lovin it???:rolleyes:
Jayl13 05-25-2007 09:50 AM
Yeah, Got the intierior all out, replacing alot of the headliner panels, putting in new wiring and overhead lights, took those moron air horns off the deck and patched that hole (was through bolted not just surface screwed on there) Redoing the cushions in the cabin and getting rid of the black and pink seats and side pads, Putting in a new floor (waiting for that to show up) ordered the Jessel valve train and new push rods and gaskets, new heli coil for the one bolt hole in the head that someone stripped out a little bit. Starting some of the airbrushing too, bought a new sand blasting or media blasting cabinet so i have been stripping brackets, parts, valve covers and cleaning all the bolts one by one for it so when it goes back together its perfect. Hell its an apache, it has to be perfect.
No excuses why it should not be perfect.
I have the time and the talent so im stripping it all down and doing it right
Hot Duck 05-25-2007 10:57 AM
Sounds like it is coming along pretty well. The engine problem may have been a blessing after all. If it hadn't happened you would probably be running the boat like it was rather than doing this work. Now one project has become many and I can honestly say that I know how you feel. It will all be worth it in the end! Just don't forget to post pictures of the transformation. You know we all love watching projects come along.
Jayl13 07-17-2007 12:09 PM
Im still working on the interior, Have talked to Jessel about the rockers, I sent them in for they wanted to see them and evaluate them. Problem is it is so damn hot here, its hard to work on the boat, the cabin is probably 175 degrees when you climb in there and you cant spend that much time down below before you are ready to pass out so im taking it slow. Cutting all new wood panels and re-wrapping them one at a time and installing them. Redoing all the lighting wiring as well since it has seen better days and has a noticeable amount of corrosion and the lights are all shot so they are all being replaced. Like I said though, its just SO hot down here that you have to work at a VERY slow pace so you dont keel over and pass out. Gallon of water an hour or so is average when im working on it during the day.
I dont expect to see her float for another year or so, Im taking alot of parts off, taking them home (bought a sand blasting cabinet) and cleaning everything up and painting everything bit by bit so this is going to take a while, this is a little bit BIGGER than the baja was and well im putting ALOT of time and effort into it all, I dont want this boat to look half assed in anyway shape or form so maybe next summer she will be ready to hit the water.
Also still working on the 77 Trans am. That engine should be done in a few weeks and thanks to Laz at Mesa, Should be up towards 600 HP with that bad boy!
Woohoo so I have alot of things going on and im just taking my time with it all! Its fun!
