28 brave owners  need exhaust help >
Old 03-26-2012 | 11:16 AM
Default 28 brave owners need exhaust help
Any chance one of you 28 owners can help me. I have stock Merc exhaust , and looking at used tubular stellings. Does any one know if there is a clearence issue down the middle ??? Can I use any ol' bbc tubular header ????? I had heard the 28 where built with the motors real tight together ?????
I believe 36 inch spread is typical ??
ANYBody HELP ???????
[email protected]
bigmotor is offline
Old 03-26-2012 | 12:28 PM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
[email protected]
call me 609 317-5466
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 04-08-2012 | 03:01 PM
Not sure what u r doing for engines but I have a set of stainless marine headers set up for a 28 brave with tall decks. They are dry to the tail and fit right through factory transom holes. Let's say I had to do some reworkIng to make them fit
They work great and can b for sale if you need them
Dave
delsol is offline
Old 04-08-2012 | 07:01 PM
Default Headers
Dave
There is 2 sets of stelling's available used, full tube stainless, but not sure that they will fit the 28's.
My drives/motors are about 34 inches on center. Most boats are 36 on center. Didn't want to spend several thousand , and find out they don't fit. I have 502 efis with bravos...
I am interested in what you have also.. Are yours the cast aluminum units ?? What are you running now ??
Thanks Scott
EMAIL IS BEST, or post .
[email protected]
bigmotor is offline
Old 04-10-2012 | 09:56 AM
CIG3's Avatar
I'd go with the Stainless marine. Lighter than tube headers and less chance for leaks in the future. The Hi Torques will take 750HP with no issues.
CIG3 is offline
Old 04-10-2012 | 10:10 AM
+1 on stainless marine.
I'm running stainless marine on mine. Its relatively easy to pull and drop in one motor without removing the exhaust. Spark plugs are a biotch, but can be done fairly easy if you pull the risers off first.
TexomaPowerboater is offline
Old 04-10-2012 | 10:25 AM
JCG
So, 34" is the distance, center to center?
+1 on the stainless marines. My headers died and replacement cost is HIGH!...
JCG is offline
Old 04-10-2012 | 09:01 PM
Yes they are 34" centers. It was a bit of work to get tall decks in, but it worked well once in. Spark plugs were much worse to change with the blower engines in...
delsol is offline
Old 04-24-2012 | 05:29 PM
JCG
Measured mine this weekend and found 33", center to center. I measured and re-measured and could not get 34", so for mine 33" it is. Any thoughts??
JCG is offline
Old 04-25-2012 | 06:36 AM
The Illustrious One
Veteran: Navy
That's very close what engines do you have????
