Chris Cat Projects
Few things wich are plan to make before next season..
- new fuel tanks both side - new outside doors to cabin (no doors at all at the present) - door to the toilet room - cabin seats both pontoon side - dash pantings - wideband o2 sensor for both engines - + others wich havent pop up in mind yet.. Winter are diffucult time to make anything when boat are covered in backyard, so thread will move slowly. On going comments and ideas will be wellcome.. |
2 Attachment(s)
Where we stand now.
Both fuel tanks has cut open in cabin. Plan is put new ones inside in older tanks. New ones are smaller and tanks dos not come in cabin anymoore. Other pic show how cabin seems now. For the O2, one possible is PLX system. http://www.plxdevices.com/wideband.php |
What a.. sun gave first little taste of spring shine :thankyouthankyou:
Still snow every where, winter go away, go away.. Pair PLX DM6 units and nuts for exhaust tubes has arrived. also pair of seats in the cabin has found and waiting assembly. |
Hmmm. Was size capacity are the original fuel tanks each?
Sure mounted forward a bunch. Are all Chris Cats fuel tanks mounted like yours? I know that the AO and Awesome vary a small amount, but both are mounted rearward of your location. |
Originally Posted by ROTAX454
(Post 3631796)
Sure mounted forward a bunch. Are all Chris Cats fuel tanks mounted like yours? I know that the AO and Awesome vary a small amount, but both are mounted rearward of your location. Not all chris has same, this boat are orginal race hull with three man side by side cockpit. I have measure that new tank volume (under cockpit) Are near 250l/66gal per side total 500l/132gal. Sure its almost half than orginal but i want More deep/space in cabin area.. |
interesting traed I'll follow for sure !
1 Attachment(s)
Originally Posted by jeff32
(Post 3632793)
Anyone know what are those bungs ?? |
O2 sensor
Originally Posted by EWB
(Post 3635449)
O2 sensor
It looks like, thats make O2 sensor assemply VERY easy. :) I have allready separate short bungs for welding...no need for those anymoore. O2 to one side... What about EGT sensor to other side, Is it any worth in that place ? |
1 Attachment(s)
Originally Posted by shootitup
(Post 3632166)
Orginal was 400litres/205gal per side, total 800l/211gal.
| All times are GMT -5. The time now is 02:26 PM. |
