Testing the 36 tomorrow >
Old 02-03-2006 | 07:54 AM
BajaRunner's Avatar
Default Re: Testing the 36 tomorrow
Originally Posted by baja36ft
IF YOU ARE RUNNING RICH AT IDLE I WOULD TRY A 2INCH OPEN SPACER BEST THING IS TO PULL A PLUG AFTER A
WOT RUN AND SEE WHAT IT LOOKS LIKE BUT WHEN I DID
MINE WE PUT A 850 CARB ON WHAT IS THE TIMING SET AT?
Timing is at 34 degrees. We pulled a plug and it was black, but bob said that its hard to read plugs, because as soon as we back to idle, they turn black.
Im wondering if i need an 850 or if its something else.
We were thinking of doing the spacer and 850 at the same time, I just want to make sure i need it before spending $1200 on some new carbs.
BajaRunner is offline
BajaRunner's Avatar
Originally Posted by customtouch
BajaRunner, Sorry to cut you short today on the phone. When I tried to call you back I didn't have your number. To answer your question, the only person I know of for glass work around here would be Rick George out at Emerald Point Marina. I have not met him personally or had any work done for me by him, but I have been told that he is suppose to be good. The only other people that I have heard do a good job is Custom Boats of Austin, but then again I have not personally had anything done by them. Sorry I can't give you a definate answer but I hope this helps.
Thanks david, ill give em a call.
Old 02-03-2006 | 11:51 AM
hey bajarunner i had some 540 bulldogs i am selling the intakes and the carbs make you a hell of a deal i just had the carbs done by dean nickerson.. 850's chopped ..
AeroSpeedMarine is offline
Old 02-03-2006 | 12:14 PM
BajaRunner's Avatar
I sent you a pm.
Old 02-05-2006 | 09:15 AM
baja36ft's Avatar
Good Talking To You Jason If I Could Help In Any Way
Call Me.
Stan
baja36ft is offline
bruin_d
06-01-2008 08:56 AM
PREDATOR POWERBOATS
OPA/The Jersey Boyz
4
11-27-2007 09:07 AM
lucky strike
10-24-2004 08:05 AM
