Any benefits in adding boxes or shorties to a 36 Outlaw/575sci's? >
Old 02-02-2006 | 05:26 PM
Harper220's Avatar
Default Re: Any benefits in adding boxes or shorties to a 36 Outlaw/575sci's?
Originally Posted by JaayTeee
Haven't bought anything yet,
probably going with the Bravo shop
one's.
Mine has Stellings boxes,
with the 32 bravo's it will run 85
hitting the rev limiters.
With the 32 maximus's it ran 86-87
but was only turning 4900.
This is where the shorties come in
.....getting the 5 blades "dried out"
should pick up the rpm ( and, hopefully,
the speed)
Any particular reason why you decided to go with the Bravo Shop lowers? Any predictions on what the shortie drives will do to your speed? Do you like the 5 blade props better than the Bravos?
Harper220 is offline
Old 02-02-2006 | 05:31 PM
Harper220's Avatar
Originally Posted by Dock Holiday
I had a friend with an 01 36 Outlaw with 850 HP whippled engines and 1 inch shorter IMCO's and he ran in the low 90's.
I think the best he ever saw was 94. The boat planed and handled very well. He did everything at once and I cannot tell you if the lowers helped or not.
Here are some pictures.
2 850's and low 90's? That doesn't seem right? Either the 36 Outlaw just wasn't meant to go any faster or the 850's really aren't 850's??
Old 02-02-2006 | 05:46 PM
The 5 blades rule ,
they got me on this whole shorty kick.
With 2" shorties, the propshafts will
still be 1" below the bottom, the'll still
be running submerged.
The IMCO lower has more surface
area, due to the larger nose cone,
than the bravo shop lower.
I'm not running the speeds that require a huge
nosecone, so this will only be added drag.
The bravo shop lower has a cavitation plate
incorperated in to it, where the others use a
bolt on splash plate.
The goal is 90
JaayTeee is offline
Keith Atlanta
Drives and Lower Units
26
01-24-2009 01:55 PM
Keith Atlanta
Baja
19
10-12-2008 10:22 PM
jbbeard
Wanted
0
01-31-2008 03:56 PM
Harper220
Prop Talk
11
02-24-2006 05:46 PM
Back4More
04-11-2002 08:03 PM
