Porpoise problem >
Porpoise problem
Porpoise problem
Old 10-17-2006 | 08:16 PM
Steel Outlawed's Avatar
Default Re: Porpoise problem
Originally Posted by irishtornado
Bill are you saying I post alot regarding Baja's? I'll prolly never post as much as I did over on the other site, but some good people are over here so I figured I'd come hangout instead of lurk.
And Dock is here too.
I had the same thing with my 25 Outlaw and 33 Outlaw. But the 33 only does it when it is full of fuel. The 25 would do it all the time at mid range with out tab.
Steel Outlawed is offline
Old 10-17-2006 | 09:11 PM
speedboatr's Avatar
Thanks again,
I will check the hull and probably just add the tabs . Any recommendation on what trim tabs to use. I remember seeing a Lenco racing tab in a recent boating magazine that looked good.
Thanks Speed.
speedboatr is offline
Old 10-17-2006 | 09:34 PM
Playn's Avatar
I didn't go fancy. I used Bennett Sport Tabs on my 250.
Playn is offline
Old 10-17-2006 | 10:12 PM
AIR TIME's Avatar
If you are going to run in the rough get the k planes 280s or 380s I had the trim tabs bennetts boat came with them in 88 , I broke them off 2 or 3 times in one yr . I love my 380s wish I had them all a long. boat flys nice and level now, but thats having the 2'' shortie two.
AIR TIME is offline
Old 10-18-2006 | 07:26 AM
Dock Holiday's Avatar
Charter Member #34
Dock did you notice any speed improvements from doing it. I know mine has hook, but they are talking around 3k to blueprint a 3' triangle thought that was a little steep.
Dave,
I removed the A/C water intake fitting from the bottom of the hull and blue printed the last four feet of hull.
We also did engine modifications at the same time. Overall I picked up a total of 4 MPH. There was a pretty good hook in my hull. It takes longer now for the bow to drop when coming on plane without tabs, but other then that you really do not notice any difference.
Is it worth it? Probably not.
Dock
Dock Holiday is offline
Old 10-18-2006 | 07:28 AM
Charter Member #34
Playn,
You have one really sweet classic Baja.
Dock
Old 10-18-2006 | 09:47 AM
Originally Posted by Dock Holiday
Dave,
Dock
Thanks for the input Dock. I'm looking for little things to bring the overall performance up and my boat does porpoise. I'll just keep using the tabs. Thanks again for your input the other day on the phone too. Gave him a call.
Irishtornado is offline
Old 10-18-2006 | 09:57 AM
Charter Member #34
Always nice to talk with you Dave. Give me a call any time. I saw your post over on General Discussion regarding Tyler and the 496 engine. Let me know what you decide.
Old 10-18-2006 | 03:17 PM
I'm in the figuring out part with Tyler now. What is going to work best for my application and budget. Thanks again Dock
SCARAB98
Active Thunder
53
09-09-2008 12:54 PM
HALLETT FAN
Prop Talk
24
01-31-2008 03:28 PM
rslick
Donzi
22
11-26-2005 07:03 AM
Schweeng
08-26-2002 02:12 AM
