electrical problem >
electrical problem
electrical problem
Old 04-28-2008 | 09:49 AM
Since you fixed your electrical issue, I thought I would hijack your title.
When I took off my AC panel to hook up the new ac unit, I noticed that the diode on the main breaker was blown and some wiring nearby had the sheathing melted away showing bare copper.
Has anyone seen this or had this happen to them?
The dealer took 2 weeks to get in the breaker, it would have been longer had I not got Sherry Conkel involved from Baja. Well the breaker shows up and there is no Diode attached and the dealer cannot find a schematic with this setup on there. My son is an electrician and has never heard or seen a setup like that, appearantly there are 3 breakers that make up the main, and the diode crosses from the hot of the top to the neutral of the 3rd.
Installing this ac unit most likely just saved the boat, that was a fire waitn to happen. I am thinking the same person on the line installed the electrical that did my stereo, all those cables were labeled wrong and hooked up even worse, I had to re-wire the whole stereo and that was on a brand new boat. The dealer had tried but they only followed the labels on the cables which ended up blowing one of the channels on the amp, which they replaced. Think the QA guy was asleep that day.
GoodTymn is offline
Old 05-06-2008 | 01:40 PM
They must have been asleep. That is no good though - any potential for a boat fire is never a good thing.
I was impressed with the wiring on the '095 275... everything was well connected, clean and routed very well.
jswfl09 is offline
gripit
Cigarette
4
08-29-2008 11:41 AM
wheatieworld
2
09-30-2006 07:13 AM
riski bidness
1
08-11-2006 06:58 PM
kennyo
3
05-04-2006 01:33 PM
RJ1340
1
05-02-2004 10:17 PM
