Rebirth of a Baja >
Rebirth of a Baja
Rebirth of a Baja
Old 03-06-2009 | 08:35 AM
  #601
boatman22's Avatar
Originally Posted by TEAMBAJA
boatman, while we are off topic, repeat after me........
a .38 Special is NOT a Faja!
Doc says it best with "Baja before Fountain".
I know....I just like saying it.......it's like saying FU to Reggie
When Fountian buys Donzi ........Fonzi....Sorry Mark off topic again
boatman22 is offline
Old 03-08-2009 | 10:46 PM
  #602
Dock Holiday's Avatar
Charter Member #34
Saturday March 7, 2009
Launched at PYC on LKN at 11AM.
Jeff "SteelOutlawed" was on board and we ran with Mike "Socalstone" and his buddy CJ who were in Mike's 26 OL with a 600 Merc.
After getting some oil temperature and checking that everything was good we made a speed run. The air temp was right at 80 degrees but the water temp is still cold around 50 degrees. I had a full load of fuel (Dumb), and the water was fairly flat. The best speed we saw with the stock 32 pitch props at 5500 RPM was 88.1 MPH on a hand held GPS that Jeff was in charge of operating.
This is with 75 gallons more fuel and a second person since the last time I ran the boat.
I think my water leaks have actually been coming from the sand strainers and we tightened them up on the water but they still need some attention. Also I have a very slight oil leak on the starboard engine and a little larger leak on the port side. Of course a little oil makes a real mess and when coupled with the water.
A buddy that is a mechanic got onboard to check it out and thinks the oil is coming from the valve covers. He plans to come over to the house and help get these two issues resolved.
On the boost pressure gauges I'm seeing 5PSI.
A little tweeking on the props and we should be easily in the 90's with fuel fuel which is where I want to run.
The engines are awesome and pull like a son of a gun from 65 to 85+. The outdrives Dick built are hanging in there very well so far and it is really hard not laying into those throttles with all that power at hand.
The hull handles the extra speed with no issues at all.
Dock Holiday is offline
Old 03-08-2009 | 10:54 PM
  #603
Charter Member #34
I had a new bracket for the power steering reservoir made that is three inches taller than the one we had on there and it apprears that this may have solved the problem getting the air out of the steering since it moved the reservoir higher than the pump.
Thanks to Sonny at Deal Machine for making the bracket and thanks to my good friend Rodney "Spittin Kitty" for polishing it.
Attached Thumbnails Rebirth of a Baja-march-7-2009-107.jpg   Rebirth of a Baja-march-7-2009-108.jpg   Rebirth of a Baja-march-7-2009-109.jpg
Old 03-08-2009 | 11:58 PM
  #604
US1 Fountain's Avatar
Ginger or Mary Ann?
Doc, back in post 91, you show your drives. Any closeups of the caps and what brand are they?
US1 Fountain is offline
Old 03-09-2009 | 06:29 AM
  #605
Steel Outlawed's Avatar
I believe she has a few miles an hour left in her. When the props are labbed it should do low 90's easy.
Steel Outlawed is offline
Old 03-09-2009 | 07:54 AM
  #606
Dock;
More good news as far as you progress.
I still am thinking you need to try labbed 34s to see what happens with them. Am thinking about the same RPM as now with added speed. Not real sure how high you want to go RPM wise.
Keep us informed!
Mark
GETTINBYE is offline
Old 03-09-2009 | 10:02 AM
  #607
Charter Member #34
Max Machine Worxs
They did not meet Dick's specifications on tolerances however and he did just a little machining and fine tuning to them when he set up the drives.
Dick Tryce "Mr. Gadgets"
Dick's Performance Marine
Attached Thumbnails Rebirth of a Baja-imgp4891.jpg   Rebirth of a Baja-imgp4892.jpg
Old 03-09-2009 | 10:04 AM
  #608
Charter Member #34
Originally Posted by GETTINBYE
Dock;
Keep us informed!
Mark
Mark I believe you are right and I would like to try some labbed 34's. I plan to get the 32 labbed and matched up and see what they do and if I come across some 34's I will try them. The rev limiters are set at 5750 RPM.
Thank you
Old 03-09-2009 | 03:55 PM
  #609
Dock;
With the limiters set at 5750 you will or should be on them after labbeing the 32s I would think.
Lets see: Labbed 34s at 5500 at the present slip % = approx. 93.67 MPH. NOW if you could turn them at 5750 you are at 97.93 MPH using your present slip #s.
I have not said anything up till now but in the begining I was thinking in the 94 to 96 range based on other sources, info, and guesses.
You are well on your way my friend!
Mark
Old 03-12-2009 | 03:30 PM
  #610
Custom Interiors & More
Dock,
I think that you will only be @ 5650 (max) on RPM's by labbing the 32's. Have them cupped to 33's like we did on Pokerface. A Merc Rep. had told me at one time that the 34 series Bravo props were never good performers for some reason. The same is true on the 25 Mirage Plus.....for some reason certain sizes don't perform as well?
Also, I know this is off-topic but we are sending you a gallon of PURE Ohio sweetness. Lane, and his brother along with a half dozen friends make this every spring. It takes on average 65 gallons of Maple sap, boiled-off to make just one gallon of syrup.
XT
XT-Innovator is offline
