Rebirth of a Baja >
Rebirth of a Baja
Rebirth of a Baja
Old 03-26-2009 | 10:06 AM
  #621
Steel Outlawed's Avatar
There could be some very high pressure going through those strainers. Do you think you could put some kind of pressure reducer.
Steel Outlawed is offline
Old 03-26-2009 | 12:17 PM
  #622
Dock Holiday's Avatar
Charter Member #34
Originally Posted by JasonSmith
Yup. Too much pressure. About $600 will cure that issue.
Is that all?
Tell me more oh great one.
Dock Holiday is offline
Old 03-26-2009 | 04:15 PM
  #623
crayolacrazy's Avatar
Originally Posted by Dock Holiday
Looking for opinions and suggestions regarding water pressure.
I am getting water leaks out of the sand strainers. They are as tight as they can possibly be tightened. It leaks where the glass bowl contacts the metal body and there is an o-ring there.
There are dedicated water pick ups on the transom running to the sand strainers and then to the intercoolers under the Whipples.
I do not have any pressure gauges on them but there is a good steady water flow while onplane.
Could the pressure be exceeding what the strainers can handle?
Doc it looks like your pick ups are 1 inch and gets necked down to 5/8 s hose try shortenig the angle of pickup, closer to the bottom I would say if your picks hang more than 1/4 inch below thats enough. before you cut pickup take the screen out of sand strainer to releive pressure just to see If glass still leaks .I think the pickup need restricked some how .get valve put it before strainer close 1/2 way .
crayolacrazy is offline
Old 03-26-2009 | 04:38 PM
  #624
JasonSmith's Avatar
Is that all?
Ahhhh. $600 first please.
Actually, I built my own pressure relief valves about 2 years ago. I found it was cheaper to buy the off the shelf ones than building my own.
They are pretty cool though. I'll see what I can dig up for specs on them.
JasonSmith is offline
Old 03-26-2009 | 04:47 PM
  #625
http://www.watts.com/pro/_productsFu...pid=3432&ref=2
Baja_man is offline
Old 03-26-2009 | 04:52 PM
  #626
Jason did you make shirts yet ,for the 90 mph club
Old 03-26-2009 | 04:54 PM
  #627
JasonSmith's Avatar
No. You want one or two?
Old 03-26-2009 | 05:07 PM
  #628
I used these valves once you get sand in them they stay open I got spanked from teague 100.00 a peice he claims there different than the ones from home depot they do look the same
Old 03-26-2009 | 05:13 PM
  #629
Put them on tanks , on the back ,baja speed changes you on the front Ill take 12 xxl tanks 12 tee,s white of course use the same colors Call me for real 4127810881
Old 03-26-2009 | 05:20 PM
  #630
JasonSmith's Avatar
I've put in a phone call to a guy I know. I'll call you when I know something about them. Should be tomorrow.
