pop up bow light
Always put your drill in reverse and let it kind of grind away the gel coat first. Then put it back in forward and drill the hole. The gel coat is brittle and if you are too aggressive drilling straight into it the gel coat will chip and you have a big mess.
Just put the drill in reverse and put it where you want the hole and pull the trigger and when you have a cupped area in the gel then it is safe to drill.
Sorry I don't know how to explain it any better.
Good luck
Good luck with the project and let us know how it turns out.
I also like to put a large piece of masking tape over the area and drill right through it.
SO i have the bow light from accon, like the one in the link, but its is not going to fit very good on my 252 so i am returning it to accon and getting htem to send me this one.
http://www.acconmarine.com/pc-110-5-...bow-light.aspx
I will let you know how it goes.
Just tagging along. I have a 252 that I did the same thing. popped the light right off. I have been wanting to put a pop up in it's place. Please let me know how it goes. Pictures would help too.
Ok, so both the accon marine parts 210-m, and 211-m are two big for a baja 252. The 252 has a slight indention on the nose and both lights would bolt on the high parts of the deck leaving gaps and looks bad. So looking for other branda os pop up lights. I KNOW someone makes one that fits because i alomost bought another 252 when looking for one that had one that fit great. IDEAS?
