External Transducer for Depth Finder >
Old 04-01-2009 | 12:52 PM
Default External Transducer for Depth Finder
After a summer of my depth finder not being reliable (because the yahoo before me had the trhu-hull puck replaced and SPLICED the wires!), I decided to add an externally mounted transducer. Followed the templates and instructions but my father in law drilled the mounting holes for the transducer bracket 3/16" too low, so now the actuall trasnducer sits that much lower in the water than what the template holes would have allowed for? In your opinion, will that make any difference? Humminbird says it may throw a rooster tail. Can't imagine that with twin engines/props and a platform back there in non-glass like waters... Thoughts? Thanks in advance.
imartin is offline
Old 04-02-2009 | 02:31 PM
Lots of views on this post, but no replies. Anyone think this is going to be an issue for me???? Have not been able to lake test it yet as the 5200 is still curing! Thanks.
imartin is offline
Old 04-02-2009 | 03:46 PM
Mine is on the transom, but at the right height. The only problem is it may trip it up due to the presure on it. I thought they were slotted so you could adjust them?
3030hunter is offline
Old 04-02-2009 | 04:57 PM
yep, they are slotted and mine is as far up as it can go. Again, with the holes being drilled 3/16" lower than what the template said, the darn thing is sitting lower than what I wanted. Hope to god I don't have to drill new holes....
imartin is offline
Old 04-02-2009 | 07:29 PM
Smitty's Avatar
If you have to drill new holes, just fill the old ones with Marine Tex epoxy and wet sand flush. It will be fine.
The issue I see is that you are probably going to break of the transducer at some point. Those external ones are not really made to be used on a go fast type of boat. I know from personal experience after breaking off 3 of them.
Smitty is offline
Old 04-03-2009 | 03:26 PM
hmmm. Havn't thought of the darn thing being ripped off the transom. Looking down the boat's hull a small portion of the transducer is directly behind the transom. Not like this thing is just hanging a foot below the hull and wide open exposed. I just can't see 3/16" of an inch creating a make/break situation. looking forward to testing the thing out!
imartin is offline
Old 04-04-2009 | 03:23 PM
dude go on ebay and buy yourself the eagle eye tramsom mount/thru hull sensor assy. it comes complete with gauges. then go to loews and buy the 50 min marine expoxy and follow the instructions for thru hull mounting. I paided $55 bucks for it last year and to this day it still brings tears to my eyes...worth every pennny. forget about all that transom mount BS it will bend up at some point and read wrong.
and I have a twin step hull! and it still reads acurate.
larry da outlaw is offline
