How fast should my 272 run???
Sounds like you are set up correctly to me. My 24' boat ran 55 with 330 HP & 21pitch at 4700 RPM. If you have not done a tune up, change the cap, rotor, wires, plugs. You can advance your timing from 8 deg at idle to 12. That will give you 36 deg total timing, assuming you have the 24 degree modual. Be sure you have good gas.
isnt a 260 actually a 26ft boat? The 272 is only a 25ft boat with a 2' integrated platform?
Either way, right about the same speed.
The run was awesome, definitely was catching some good air.... I will be back next year. You coming around for the Raft off or cumberland?
Seams like it should be faster but the 330 just dont have the grunt like a mag does. Good motor never had any problems with it ran like a champ. Just not the fastest.
Raft off and Cumberland are hopefuls. We just have to see how things shake out.
I have a 1994 Baja 272 equipped with a 330hp merc 454, bravo one drive and 21p mirage prop.
Trimmed significantly with almost no fuel, and by myself on glass water I get the speedo to show 56, handheld gps says 53/54, this is @4600rpm....
I posted in the general section, and Air Time seemed to think this boat was running pretty slow.
I am considering some power upgrades this winter. Is this running slow, or am I right around what it should run.
Thanks in advance!
Thanks in advance!
51.8 MPH
Using a 15% slip factor which is average for a Baja.
http://www.rbbi.com/folders/prop/propcalc.htm
Scott see if you can scrounge up a cheap 22p Bravo. I liked the 4 blade for getting out of the hole and to me felt more hooked up in the water. You'll get varied opinions on this, but I think you'll gain a few mph with it. Might have to lab it though.
