-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Ink on vinyl... (https://www.offshoreonly.com/forums/baja/217434-ink-vinyl.html)
JBOUTLAW 09-24-2009 10:24 AM
Ink on vinyl...
Guys-Someone apparently marked my seat with a pen. Any reccomendaions to getting an ink mark off of vinyl?? I've tried all my boating vinyl cleaners, magic eraser, and a few other products. It also happens to be on a colored (yellow) portion so I didn't want to try bleach. Any suggestions?? Thanks!
poiuy10 09-24-2009 10:37 AM
Ive taken pen out of a shirt with hair spray.... try both aerosol and spray type. try in a spot not in plain view in case it dis-colors. good luck !
NoWake200 09-24-2009 10:40 AM
I have had great success with this product...
http://www.griotsgarage.com/product/...rrivals&page=1
A friend of mine used it once to get dried blood off a leather seat in his truck. Removed it with no problem. We carry the small spray bottle on our boat and use it all the time.
I would try the small bottle first to see if you like it... PM me and let me know if it helped.
Good luck and I hope it helps.
G-Spot 09-24-2009 10:43 AM
May try mean green. Let is soak and use scrub brush. Never tried it on ink but it works well on a lot of stuff.
sacaja 09-24-2009 11:04 AM
bio-kleen, vinyl cleaner and conditioner
Perlmudder 09-24-2009 11:21 AM
I would give the magic eraser a try, it has worked great for me, never on pen, but for $3 how can you not try it
XT-Innovator 09-24-2009 12:53 PM
Rubbing alcohol 99% is what we used at the plant.
XT
Baja_man 09-24-2009 02:18 PM
clear PVC pipe cleaner...
US1 Fountain 09-24-2009 04:27 PM
That's acetone. Gotta be real careful using it on vinyl.
I've seen ink stains disappear over time just by being out in the sun. Might be better to use a cleaner lightly, then let the sun do it's job, vs scrubbing the chit out of your vinyl trying to get the stain out immediately.
XT-Innovator 09-25-2009 11:17 AM
Acetone will remove the stain guard coating, and melt the vinyl! I do agree that many stains will get bleached-out from the sun.
