Horn problem
My horn does not work. I pulled off the plastic cover. Is there screws to pull out the horn. Do the horns usually go bad. My boat is a 232 Baja 1998 model. What is my next procedure to fix the horn. Thanks
Custom Interiors & More
XT
I gave up on getting mine to work long ago. replaced horns, switch, etc. to no avail.
So I went to AutoZone and bought a couple of MUCH bigger horns, mounted them behind the side engine vents, ran a couple of wires to the switch, and all is well again.
