25OL..Stellings Box..IMCO shorty.. >
Old 06-21-2010 | 08:04 PM
Originally Posted by Keith Atlanta
+2
Why do you want to run at 4800 RPM?
It's not that I want to run 4800 but it seems the slip was lower. I am going to try a few things first before any more labbing
1) Try 26P B1
2) Stock lower
3) 1" Spacer
something should pan out
On a side note a potential problem I see is with the box and nose cone I only have 14" clearance from grount to nose cone tip. Any parking lot that has a steep decline, I am ohh so close to dragging the tip. I know I can add a protector to trailer but first off, I'm not sure who could do this and if it would look good or how much. Has anyone had any issues like this before?
Baja_man is offline
Old 06-21-2010 | 09:07 PM
The slip was lower because your prop was deeper in the water. Complete different setup now..
Irishtornado is offline
Old 06-21-2010 | 09:08 PM
You only have 14" when drive is in full trailer? something isn't right there.
Old 06-21-2010 | 09:27 PM
Yes 14" on full trailer........it sits farther back now and think it may be an issue. I could raise the bunks a bit but only would gain 2" at most.
Baja_man is offline
Old 06-22-2010 | 09:17 AM
Registered User
You might look at getting a lower hitch on your truck. Just make sure it has the proper load handling rating. If you have room to lower the front and not drag, the back of the boat will raise up giving you more clearance.
russellhorn is offline
Old 06-22-2010 | 09:25 AM
You won't have any issues. Your trailer will hang up before your drive ever drags...
Old 06-22-2010 | 09:48 AM
I really don't like the feel of the 3 Blade but I had it at the cottage at thought I would try it.....didn't like it.
As Irish said, I may put the stock lower back on just to see what happens. That would give me a 5" drive height, still an inch shorter than stock but will give me another variable to work with.
I am trying to find a 26P B1 to try this weekend.
I raised my engine and drive up 3", it used to be 8" now it is 5". NO ext box and a standard bravo drive. I am running a Mirage 25p with double cup on the tips. My slip numbers are 9.8% @5200 RPM 74MPH. This was a few weeks ago when the temps were lower. I have not tried any other props yet.
I am probably at the limit for using the Mirage. Like was said before a 4 or 5 blade prop will most likley work best for you. Let us know what you find out.
jeffswav is offline
Old 06-23-2010 | 07:53 PM
AIR TIME's Avatar
1) Try 26P B1
2) Stock lower
3) 1" Spacer
make sure you do one thing at a time, like 26b1 by its self. then lower or spacer just add one thing and test.
AIR TIME is offline
Old 07-14-2010 | 10:41 AM
Any more results to post?
jeffswav is offline
Old 08-03-2010 | 01:23 AM
articfriends's Avatar
If you haven't tried a 26 yet send me a message as I have a stock 26 a labbed 26 and a 24 I would let you try,are you from the boyne area,I think I met you a few years ago at the poker run on JB'S boat,Smitty
articfriends is offline
