-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Prop for Baja 29 OL? (https://www.offshoreonly.com/forums/baja/238895-prop-baja-29-ol.html)
Teo 09-12-2010 12:13 PM
I have bought myself a Baja 29 OL with 2x454(7.4L) MPI.
The only thing is that it hasnīt got the right propellers.
So I ask the oracle of OSO what would be the ultimate props
for this boat?
(Sorry bout my spelling, Iīm from Sweden...):bigbird:
JWoolever 09-12-2010 01:08 PM
It makes a difference if there are 454 mags or not, here is a discussion on props using non mag motors, if you need some like new Mirage plus 3 blades i do have some available in 23p.
http://www.offshoreonly.com/forums/g...29-outlaw.html
Teo 09-12-2010 01:32 PM
Thanks. Whatīs the difference between Mirage and Mirage Plus? I have Mirage 23p 3 blades. I dont know if there is a "plus" there or not.
jmeng 09-12-2010 01:57 PM
How does the boat do with the Mirage 23s? What are you looking to improve?
Irishtornado 09-12-2010 04:07 PM
7.4L 454's are 310hp or 330hp and most likely are ideal with 23p Mirage Plus props....I'd be trying to spin a 22p Bravo myself and if your shy a few RPM's have them labbed by Bblades...
What year is the boat? They raised the X dimension in 02 on all Baja's and started propping them with 4blades instead of 3 blades...
Teo 09-13-2010 04:41 AM
It feels like the engines doesnīt have to work at all. No problems with the acceleration but the topspeed is about 61 mph and I want to go faster. It feels like those engines has little more to give.
Teo 09-13-2010 04:43 AM
The boat is from -98. Dont know if they are 310 or 330. Have to look that up.
jmeng 09-13-2010 09:14 AM
How many rpms are you turning at WOT? The 7.4s should top out at 4600 rpm. If you're hitting the rev limiters I would try a set of 25" Mirages.
jmeng 09-13-2010 09:15 AM
Assuming they're EFI motors they are 310hp at the prop. The carbed 7.4s were rated at 300hp at the prop and 330hp at the crank.
Baja_342 09-13-2010 09:22 AM
You've got 310 HP.
Having a '99 29 OL and a '99 302 powered identically, I can tell you you are running right where you are supposed to be.
My 29 with 23" 3 blades I got 62 on GPS.
On my 302 I bought 22" Bravo 4 blades. Picked up hole shot and mid range, but could bump the rev limiters.
You may be able to lab a set of 24" 4 blades, but you'll not be happy with the $$$ - MPH result.
Get the hull in some good chop and you may pick up another couple MPH. In my opinion you've got a nice, economical, reliable setup. I wouldn't waste time and money trying to chase a MPH in that package.
