advice on bottom hook >
Old 02-09-2011 | 09:36 PM
Default advice on bottom hook
wanting advice on sanding out bottom hook off 1989 280 sport. i'm switching from 330 hp. motors to 550 hp. motor. also installing 280 k-planes. outdrives (bravos)stock location
280bajasport is offline
Old 02-10-2011 | 03:03 PM
JasonSmith's Avatar
It's there for a reason. I know some that have taken the hook out & are not happy with the results, pertaining to Bajas.
JasonSmith is offline
Old 02-10-2011 | 04:18 PM
the boat poiposes if i used any trim at all with the 330 motors at higher speeds. I don't know what more power will do about the poipose. Hope the k-planes will help and maybe removing the hook.
Old 02-10-2011 | 04:39 PM
Custom Interiors & More
Agree with Jason....save the effort. Just make the boat go so much faster they are no longer in the water! Then they will only help you at cruising speeds. The K-planes will do much more to help you, or pay big money and have the bottom "blueprinted".
XT
XT-Innovator is offline
Old 02-10-2011 | 04:46 PM
JasonSmith's Avatar
At 90+mph my hooks weren't in the water.
Old 02-10-2011 | 05:06 PM
Have an 89 280 sport. With 330's and then 400's the boat bounced if it was trimmed, but just a very little tab settled it down.
Now have 540 hp 502s and will bounce at mid speed with trim. But at top speed does not bounce.
However these older bajas do chine walk as speed exceeds high 70s. It takes a lot of trial/error to get max speed with trim & tabs.
Keep us posted as you get the 550s going.
Sport 280 is offline
Old 02-10-2011 | 05:17 PM
You got it.....get it going fast enough...the'll come out
of the water
JaayTeee is offline
Old 02-10-2011 | 08:18 PM
Nightlife1970's Avatar
Switch to a good set of 4 blades. I have a set of 3 blade labs that came with the boat. It bouces with those, and rides much harder. Got a set of labbed 4 blades and it is a whole different boat.
Nightlife1970 is offline
Old 02-12-2011 | 04:21 PM
I have contemplated removing mine, but like was said after mid 60's there not even in the water. Mine has a awfull porpoise if you cruise between 53-60 MPH. After about 63-65 you can really feal the boat free up. Wait till you put the new engine in and report back with what you find out.
jeffswav is offline
Old 02-16-2011 | 09:31 PM
Thanks for the information. I will try different prop configurations first. - Thanks
