1.36gear ratio vs 1.50 >
Old 06-17-2002 | 07:43 PM
leese
Default 1.36gear ratio vs 1.50
COULD SOMEONE TELL ME HOW THE GEAR RATIO WORKS?i HAVE A BRAVO ONE WITH A 1.36 RATIO.I AM RUNNING A 23 MIRAGE.SHOULD I GO TO A 21 OR 22 OR GO WITH A 1.50 GEAR RATIO.DOES THE GEAR RATIO WORK THE SAME AS A CAR WOULD? DOES THIS EXPLAIN WHY I AM HAVING TROUBLE GETTING OUT OF THE HOLE?? I AM ALSO NOT RUNNING AT FACTORY RECOMMENDED RPM. IAM RUNNING AT 4400 NOT THE 4600 TO 5000 AS IT SHOULD BE.ANY HELP WOULD BE GREAT
Old 06-19-2002 | 04:08 PM
Caincando1's Avatar
It seems odd that that boat would have those gears. You should be able to play with they prop to get the RPM's up. Save the gear swap for last resort. I think a prop will work though. Gottahaveit's right on the money can't beat that prop for all around performance.
Caincando1 is offline
saulesses
Prop Talk
1
06-13-2007 09:12 PM
saulesses
Prop Talk
0
06-11-2007 11:01 PM
leese
Baja
15
12-05-2006 04:58 PM
88 MACH 1
4
11-16-2002 07:53 PM
Garry
10
01-27-2002 10:35 AM
