Baja 272 Shooter Questions >
Old 08-05-2014 | 12:30 PM
Default Baja 272 Shooter Questions
Looking at buying a 1993 Baja 272 shooter-
Pros and cons?
What to look for? Baja's known stringer and transom issues?
Also anybody put big power in one of these boats?
Speed vs. Power?
Thanks Tom
Satisfaction is offline
Old 08-05-2014 | 03:43 PM
I believe shooters were a tad bit lighter than normal 272. Only one bow hatch for the cabin. Should have 454 mag or 502 mag both carb those years I believe and anything less would be a little under powered. Look for low 60s mph. Obviously check stringers and transom. Fiberglass over gas tank usually balsa turns spongy over the years relatively easy fix.
LiveFREEorDIE is offline
Old 08-08-2014 | 05:12 AM
articfriends's Avatar
Pros and cons?
Speed vs. Power?
Thanks Tom
I put a 1000 hp in a 272 which is essentially the same boat and it runs 99 and change, Smitty
articfriends is offline
Old 08-12-2014 | 12:50 PM
dirtlawyer's Avatar
Years ago I had a 95 Shooter with a 502 MAG EFI. A year or so later we turned the 502 into a 509 carb motor that was putting out around 575hp. The boat ran in the low to mid 70's, handled well and was built pretty decently. If I had kept the boat I would have added longer tabs and hydraulic steering. Good luck - always liked the look of the Shooter.
dirtlawyer is offline
