Blueprinting services >
Old 03-18-2003 | 01:04 PM
HOUSTONPROP's Avatar
Default 25 too much prop
Originally posted by JS232
HI! I own a 2000 232 with a 7.4 MPI 310 HP. Prop is 23 Mirage Plus. Running 62 MPH GPS. 4550 WOT.
Would a labed 25 Mirage plus do something for me? Need for more speed. Hole shot is good right now.
I would say lab the 23 pitch prop and put a little extra cupping in it and this will work wonders/Darin
HOUSTONPROP is offline
Old 05-08-2003 | 12:20 PM
JS232's Avatar
Darin, what do you think of this : ????
«We grind our trailing edges from hub to tip rather than across the blade, thus eliminating any potential stress risers. Reducing the blade thickness from a 1/4" to a 1/8" which equates to half of the blades original thickness. But does not reduce the strength by 50%, but actually reduces the blade strength to approximately 12% of its original strength»
JS232 is offline
Old 05-08-2003 | 12:29 PM
Question JS32
WHO IS WE? AND ALL ,I, KNOW IS HOW WE DO IT HERE./THANKS
DARIN/HPS
Old 05-08-2003 | 07:10 PM
Johnny Bravo
Darrin,
Just wondering if you have finished our prop, If so when was it shipped. We are trying to go on our maiden voyage for the year this weekend and would love to test the prop.
Old 05-18-2003 | 09:54 AM
Thumbs up JohnnyBravo
Originally posted by Johnny Bravo
Darrin,
your prop should be there,it was shipped last week. Thanks again./Darin
Old 05-18-2003 | 12:06 PM
Johnny Bravo
We have not seen it yet. based on the day you shipped it, I should see it this tuesday. It is a one week delivery via UPS from your shop. With the weather we are having the outlaw has not been in the water yet.
Old 05-18-2003 | 11:06 PM
Unhappy tx too HOT
DON'T feel bad it was to hot for boating here today, unless you go very early or very late./if you need a tracking number call Kim on Monday.Thanks
Old 05-19-2003 | 11:51 AM
wonderwick's Avatar
I was wondering if some prop work or a new prop would help my 25 outlaw. It has a 496 ho mag running a 23 mirage plus. It has a great hole shot and not bad top end.. don't know what top is blew speedo line at 65+... I saw you had a 25 pitch for $250. Is this for the prop you have for sale? Would a 4 blade work better in a higher pitch for my 25? Suggestions?
wonderwick is offline
Old 05-19-2003 | 12:43 PM
Question prop
what are the rpms at running w.o.t.(wide open throttle) a four blade will slow it down .The 23 is probably your best prop but needs labbed and pitched to a 24 with a little extra cupping,should do the trick.Darin oh! the 25 pitch is sold.
Old 05-19-2003 | 04:18 PM
Johnny Bravo
I have a 25 outlaw with a 502 and Darrin just labed my prop. Our GPS speed prior to the lab work was 67.3 MPH with a 2 foot chop. Our labed prop should be here tomorrow, and we will be on the water on sunday to test it out. I wll let you know how it works. By the way our spedo tube did the same thing when it was new. We just had it replaced with a heavy duty tube.
