Baja Outlaw MPH Gauge Yellow
I am in the process of looking for to purchase a used 25 outlaw. It seems half of the outlaws I look at the MPH gauge is a rusty brown color. Why does that happen? It never seems to happen to the RPM gauge, only just the speedo. Is it difficult or even possible to drain the gauge and refill with clean clear water?
Thanks |
It happens because there is a tube coming from your lower unit that picks up water which translates water pressure into MPH. When the clear fluid starts leaking(as all seem to do over time) the gauge starts filling with lake water. Pick up a GPS Livorsi one not only will it look better but its accurate. The gauge will match the old one perfectly except for the name on the gauge. If you do this make sure you plug that water line or you will have water behind your dash. I used a screw and a zip tie and it hasn't leaked so far. Check out my thread you can see the difference in the gauges. http://www.offshoreonly.com/forums/b...25-outlaw.html
Originally Posted by iaoutlaw
(Post 4459136)
Thanks! |
Originally Posted by plexoer
(Post 4459083)
Thanks |
Empty Your inbox can't respond to your msg plexoer
You can drain the glycerin and put new in.. they sell it at drug stores
Originally Posted by Taube
(Post 4460708)
| All times are GMT -5. The time now is 11:19 PM. |
