Baja 275 with 600 SCi update Projekt
#51
Here some pics of the Drive now! Will add second cylinder next months to the mayfair.It need a bit tune the steering cylinder to get a free place inside to mount the inner cylinderplate!
I shortend the 9 inch cylider lengh a bit with parts from the 7 inch cylinder mounting stuff.I need a bit to go more inside with mounting position as i made alloy plates inside engineroom and dont like to cut them!
Now all fit perfect and boat feels very good with the shorty!Get some miles more and near no chinewalk!
Slight problems with waterpressure.I have mount Hardin SS impeller housing and see only 18 PSI!!
I have done some work at cooling circle and have now all build back !
Reroute IC water inlet (build back now for test) and open reducers in the outlet from headers.
Nothing brings my needed over 30 PSI back,except to go back on the plastic impeller housing. Looks the Hardin SS housing make lower pressure and waterflow!
Now i tried next time again to reroute the IC waterlines with the plastic pump on the motor!
I have found some guys more here that have trouble with the SS housingfrom hardin.
My engine needs 30 PSI and when get not at WOT it will go in reduce HP modus.
Michael
Michael
#53
Prop for holiday mounted! An Intimidator P5-X.
Vinyl is near ready only left side at end 2 small stripes missung.New vynyl is ordered.
Bimini gets new black head !
Next week start 3,5 weeks holiday with every day boating!
Michael
Michael
#55
Back from 3,5 Weeks holiday in Croatia now! Have no Problems at all and see good waterpressure after open the 4 waterintakes from the Sportmaster Lower a bit!
I see 82 gps mls in saltwater and high airtemperature with the Hydromotiv P5-X prop! I like this propguy and try to get one as spare now!
Regards
Michael
Regards
Michael
