Horn replacement 275 >
Old 07-03-2018 | 02:51 PM
JS232's Avatar
Default Horn replacement 275
Need to replace my horn. Anybody done this? There are no screws securing the white plastic cap. Is the plastic cover just snaped in from the outside or do you have to remove the bulk head from the cabin to replace the thing? Is there any exact same part replacement available? I dont want to mess around with custom fitting.
JS232 is offline
Old 07-03-2018 | 03:31 PM
F-2 Speedy's Avatar
Check with Great lake Skipper on the replacement horn
F-2 Speedy is offline
Old 07-05-2018 | 07:12 PM
Kefurr's Avatar
most are a snap on cover and an AFI (Marinco) hidden horn
part # 11095 is the std horn
part # 11079 is a 2db louder version
Kefurr is offline
Old 07-05-2018 | 07:32 PM
JS232's Avatar
Thank you! Seems like the right part. Do you have to work from the cabin bulkhead or is it removable from outside the hull?
JS232 is offline
Old 07-05-2018 | 08:05 PM
Kefurr's Avatar
outside
pop the cover off and should be two screws holding the horn in
Kefurr is offline
