Coming Soon
JC basically the main difference is blade thickness/the plus is alot thicker than the old mirage the plus also has the vent hole already pre casted with removable plugs the two props fit on the same pitching mold. the rake and pitch is the same.
also you will find the mirage plus has a much nicer finish compared to the older ones some were polished and the old quicksilver mirage is also the same but was always a rough satin finish when they first came out.they also rusted alot if the prop had been in salt water.
hope I have helped out JC. /Darin
Originally posted by BajaRunner
I think too the mirage plus comes with cupping and the mirage does not.
UNLESS IT IS A FULLY SUBMERGED PROP such as a tug boat or something like that I am doing a pair of brass 28x30 pitch that have no cupping.
Darin
