Over Propped! >
Over Propped!
Over Propped!
Old 04-29-2003 | 06:35 AM
Default Over Propped!
Well, I got the new 342 wet over the weekend.
I took it easy during the first 6 hours running
between 1500 - 4000 RPM's. Made 2 full speed runs
for about 30 seconds each and I could only get 4500
RPM's with both tabs tucked and the drives trimmed
as high as 7 on the indicators. I had 1/4 tank of fuel with
4 adults. The liquid filled Gaffrig speedo read 68 MPH.
I'm going to swap the 26 Bravo 1's with a pair of 24
labbed race props that the dealer has.
Hoping for 5100 RPM's and 72-73 MPH.
Whats everyone think?
Jeff
Bajaforce is offline
Old 04-29-2003 | 07:23 AM
CigDaze's Avatar
Default Overpropped...
Yep, sounds like too much prop.
You should be turning close to 5000.
The 24's should work out nicely.
CigDaze is offline
Old 04-29-2003 | 11:42 AM
I'm assuming you mean the tabs were
up, right ?
24" labs will get you to 5k.
JaayTeee is offline
Old 04-29-2003 | 12:08 PM
SSComp's Avatar
Not sure what your engines are but you sound over propped.
SSComp is offline
Old 04-29-2003 | 12:37 PM
CigDaze's Avatar
He's got 496HO's(from another thread)
4600-5000rpm.
CigDaze is offline
Old 04-29-2003 | 12:49 PM
True but 24's won't get you to 72-73 (even at 5k)
29 OUTLAW is offline
Old 04-29-2003 | 12:58 PM
bajadude's Avatar
For what its worth, I'm running 24 B1s on my 33' Outlaw. Run around 74 (gps) @ 5200 (HP500s). I've tried 28 B1s and they were way too much. I was going to try 26s but Darin wanted a shot at reworking the 24s. I should get them this week.
I think you'll pick up 400 - 600 rpm with the labbed 24s, which should put you in the ballpark.
bajadude is offline
Old 04-29-2003 | 01:20 PM
SSComp's Avatar
Better yet how about getting 28's and BLOWERS
SSComp is offline
Old 04-29-2003 | 01:34 PM
I guess I stand corrected.
Are you sure your 24's haven't been re-pitched? Your numbers would suggest a slip of only 6%.
My 2001 29 has a slip of about 10 - 11% (87mph theory, 77-78 real)
Old 04-29-2003 | 09:31 PM
liquid asset's Avatar
The 342 with ho's should run about 69 or 70 at 5,000
liquid asset is offline
