Help! All Outlaw Owners 29'-33' Twins >
Old 03-31-2005 | 10:07 PM
Default Re: Help! All Outlaw Owners 29'-33' Twins
Originally Posted by garshev
What kind of boat are you running? Older baja's ran very conservative x dimensions and were actually designed for the 3 blade mirages. True the race boats are running 4 and 5 blades but they have stepped hulls and x dimensions at the moon. They need the extra blades to reduce slip caused by the steps and high x.
The boat that I am ruuning now is a Renegade CC 29' with 250 Merc Efi's, it's a slpash of the old 28 signature hull streched an extra 1'. Deep V with no pad..old school. my last boat was a 24 Outlaw with 600hp (HP 500) motor, best handling & speed was with Revolution 4 blade prop. Recomended by Allan 4, he was racing his 24 with this prop & doing very well. The 4th blade helped give it stern lift. What I am trying to get across is try everything you can get your hands on. I was running a 25 Mirage labbed & it ran good, switched to 23" Revolution prop , better holeshot & mid range & it got the boat above the water, less resistance & I gained a couple mph on topend. Similar RPM.
With regard to my present boat, manuf. & other owners said 25" Mirages, tested everything that Throttle Up had available with Hydromotive guys, ended up dropping to a 24 blade Quad 4 prop & hitting the Rev limiters.1000% better all around. My cruise speed went up as well which is where I spend 75% of my time. Now some just fine tuning. The Renegade factory said that the fastest they had seen this hull run was 68mph empty, we hit 68 with no effort with 4 blades & should see 70 + as 1 motor was lagging 300 rpm behind due to a bad spark plug. Props can be a black science
Johno is offline
Old 04-01-2005 | 05:13 AM
32 caliber's Avatar
Outlawinil, so are you running the mirages again?
32 caliber is offline
Old 04-01-2005 | 05:14 AM
32 caliber's Avatar
What props are you using and on what boat?
Old 04-01-2005 | 07:51 AM
liquid asset's Avatar
I would agree in most cases except this one, there is no way a 32 caliber is gonna go any faster than 71 with 502's on gps all stock, do the math, my boat was hanging right with my buddys 02 33 with ho's and labbed 26's with the raised X, the hydromotives are a totally different story from bravos and also don't work well on a 33 or 29, you really have to just test each individual boat for your preferences, when my 29 gets here your more than welcom to try my mirage 25's if u pay shipping and get them back to me fairly quick, BTW on 33's and 29's from 02 and up, you have no choice but 4 blades , bcuz of the raised X, but my 32 was definatly at its sweet spot with the Hydro Q4's 24"
liquid asset is offline
Old 04-01-2005 | 08:32 AM
32 caliber's Avatar
Well I took your advise Liquid and bought the Hydros, they are marked as 25 pitch but the guy I bought them from said that one had a different rpm and that he sent them back to the factory and had them both re-pitched to 24's, so i guess I'll find out in another month or two or three !! I hate the weather in this state !(Wisconsin)
Old 04-01-2005 | 07:09 PM
baja36ft's Avatar
I To Had A 96 32ft Caliber Great Boat By The Way
With 454's Ran 71,72 With 24 Pitch Hydro's Used Bravo's Couple Of Times But The Boat Didn't Ride As Good In The Rough!!! After That I Put A Set Of 540's
In And It Ran 86 Mph With 28 Pitch Hydro's And I Also Was Spinning The Props In!!!!!!!
baja36ft is offline
Old 04-01-2005 | 09:33 PM
FX10's Avatar
More blades = less prop slippage. Our last customer tried a Hydro on his Y2K with a 496. Went from 74 to 76 GPS. The extra blade helped. Next is the 6 blade !!!
FX10 is offline
Old 04-01-2005 | 10:31 PM
outlawinil's Avatar
Yes mirage plus props are on now. BTW the first time i put the bravos on my wife said what the heck did you do to the boat...the ride sucks.
baja36- i want that speedometer out of that 32 running over 70 with 454"s
outlawinil is offline
Old 04-02-2005 | 09:41 AM
baja36ft's Avatar
that was gps with 454's that boat should run 71 to 72
with hydro's if not you have other problems.what speed do
you get know? are you spinning the props in or out?what is
the rpm? make sure the tacks are right !!!!!!
baja36ft is offline
Old 04-02-2005 | 10:18 AM
32 caliber's Avatar
BAJA36, I tend to have to agree with you, LiquidAsset said his ran about 71 with 24 hydros, so 24 hydros it is ! Did you run the props "in" when you had them on with the 454's or just with the 540's ?
