X dimension
Old 06-21-2017 | 07:04 PM
Default X dimension
Just picked up a Bravo Drive and was wondering about X Dimensions. I know the Panteras are 6 inches narrower, but looks like they run between 17 and 17.5. Anyone have any suggestions.
Joshm is offline
Old 06-24-2017 | 07:53 PM
Ok I know someone out here knows about x dimension. Currently the propshaft is 6 inches below the keel this seems low to me. I'm going with a bravo and small block and am trying to figure out what height to go with?
Joshm is offline
Old 06-26-2017 | 10:03 PM
glassdave's Avatar
Neno the mind boggler
run 17.5 on just about everything i build, seems to be a good performance X dim without being to high.
08 OPA High Points Champion
glassdave is offline
Old 06-27-2017 | 06:24 AM
Thanks Glass Dave. That's the number I was thinking about.
Joshm is offline
Old 06-27-2017 | 11:13 AM
This was an older post on this site that offered some advise.....http://www.offshoreonly.com/forums/g...boat-hull.html
sp123 is offline
Old 07-09-2017 | 09:21 AM
Does anyone know the difference in length (input shaft to output shaft) between TRS and Bravo?
jeff
hallj is offline
Old 07-16-2017 | 09:53 AM
jeff
trs 24 3/16
b1 21 13/16
outonsafari is offline
Old 07-25-2017 | 07:50 AM
Thank you.
Jeff
hallj is offline
