Mercruiser. Yup, beware. Manufacturing issues.
Can't presently cast a set of SBC Mercruiser wet joint manifolds to save their life and won't back them up.
They recognize the issue, have promised several new re-engineer and casting dates, now say sometime soon again, like the other times. Lol.....past a year aftyer bringing this to there attention. These casting have probably been around for 2 yrs or more.
So, if you are a installer, dealer, parts reseller, or private person that has or is going to buy these, think twice. I have pics of parts and notes of correspondences.
Too bad, as Mercruiser boasts being a world class manufacturer and many of use have been buying their products for a long time.
Guess they joined the modern ranks of poor manufacturing and not really giving a schit when it happens.
Bummer.
Buyer beware.
Bummer.
Buyer beware.
860246Q11 exhaust manifolds. These are the E-coated ones, but the Ceramic coated ones are effected too as they are the same castings. Verified by Merc. The coatings are done after .
no hablo englase
I switched over to d Mercruiser Dry Joint style setup . Mine are made by Barr. They have 2 different riser angles available. Going strong 6 plus years in salt.
Chris
Chris
Zoom in on pic. Tap, then spread with fingers if phone. Click few times if on pc.Valve cover side not only mismatch but leaves a extremely thin ledge for gasket to try to seal on. Gasket is 100% correct in shape/size.
This is not an oddbal set, Merc says they are all this way until they sell out the rest and change the castings.
The following 3 users liked this post by SB:
Gasket in pic is positioned perfect too. I used studs to center it.
Does the riser mate up to that? how is the riser to manifold fit? is the problem a mis made gasket? of so can you have a correct gasket made?
