Kidde Marine Fyre Watch troubleshoot
"the ground for the light should come from the extinguisher switch, the power for the light from the ignition via a fuse that may be inline as it is an add-on system"
That makes since.
They tested as a ground when connected to the tank.
That makes since.
No idea on best pricing as I have not been looking
Sea-Fire and Fireboy are probably the most common for marine systems. Believe the new ones are either FM-200 or Novec 1230. Both Halon type replacements. However, they extinguish the fires a little differently than Halon and they do not leave a corrosive residue behind.
You can't buy a new Halon system now because as mentioned it is outlawed for "new" systems. However, there is a loophole where you can recharge Halon if your container has the ability to be "re-built" Little bit of typical federal irony...Not only did our government outlaw Halon back in the 90's, they are also currently the largest consumer of Halon 1301 in the country. Lol...
Not necessarily. Most pre-engineered bottles I've seen are not rebuildable. Most extinguisher guys don't bank Halon either. However, if it's just down on Nitrogen, they might be able to re-pressurize. Not sure about FAA, but I do know, you cannot purchase new, or install a new Halon system, only recharge if the existing system parts are available and rebuildable.
