Go Back  Offshoreonly.com > General Discussion > Boating Safety
another lanyard reason >
Old 07-27-2017 | 11:49 AM
SB
I have done the same stupid schit with it attached to my waist loops or etc.
SB is offline
Old 07-27-2017 | 12:03 PM
Originally Posted by blckkat
yikes, that could have been way uglier! I need to start to get back in the habit. I miss how my old pair of inflatable vests had a dedicated rung on the bottom for lanyard. Sadly our new set of Mustangs don't have one which kind of sucks as I never seem to have a good place to hook it to.
I am not sure of the construction of the Mustang inflatable but if there is some webbing, a canvas shop can sew a ring on it. I did this on my Mustang jacket type vest. It had a ring on it but was on the wrong side. I simply had a matching brass ring sewing on the opposite side.
Padraig
Padraig is offline
Old 07-27-2017 | 01:51 PM
Sydwayz's Avatar
Forum Regulator
I can understand that. I walked away from the helm once, (just once) with the lanyard attached and killed the motors; but less likely to do such on the AT with the side by side bolsters though. Once was enough. To add though, you could accommodate a longer lanyard though, like coupling 2 coiled lanyards; and both of them being lower would allow you more movement, but also not in your way all over the dash and/or your wrist.
The Mercury red string lanyard is junk though. I always replace the mercury lanyard with one from one of the PWC accessory vendors; in color(s) to match the boat. They are much better quality and design; as the Mercury one ages fast, stretches, gets dirty, and it also doesn't float should you drop it in the water. IF you have a specific end piece on your switch end of your lanyard, you can always move that over to your new lanyard of choice with a stainless keychain hoop.
https://www.amazon.com/UL-1-Ultimate.../dp/B0000ATZBN
The little plastic pieces clip right off with a pair of dykes, and just the bare plastic (purple in this case) lanyard loop end fits right into the standard kill switch and works perfectly.
Sydwayz is offline
Old 07-28-2017 | 06:46 AM
Dave M's Avatar
Veteran: Navy
I have to get back in the habit of wearing my lanyard. I ALWAYS did with my 2 Superboats. I need to get a longer lanyard for my CC. The one that came with it is only long enough to go around my wrist. I usually clip the lanyard to the belt loop on my shorts or the drawstring if I am wearing a bathing suit.
Dave M is offline
Old 07-28-2017 | 08:17 AM
Lee's Avatar
Lee
I always use this style Saf-T-Stop Switch - CP Performance because you do not need an extra lanyard to restart the engine if the person that was wearing the lanyard gets tossed out, just flip the switch and go pick his azz up.
Lee is offline
Old 07-28-2017 | 11:11 AM
Wobble's Avatar
SORE MEMBER
Thats the one I run along with a velcro wrist band and about 6' length.
Wobble is offline
Old 07-28-2017 | 05:51 PM
i like that kill switch, and i need a new one.
this thread has about 100 views a day so far,
so how about some feed back about where to mount the kill switch so it doesn't get hung up on the way out of the boat.
anyone test theirs ?
outonsafari is offline
Old 07-28-2017 | 06:30 PM
Dave M's Avatar
Veteran: Navy
I have one now and on my last two boats. Yes, I test it once a season. The last one is hard to see but mounted to the right of the wheel. It's nice, as mentioned above, if the driver was tossed, you can just flip the switch and restart. No extra lanyard needed.
Attached Thumbnails another lanyard reason-2010_0718_104819aa.jpg   another lanyard reason-2011_0510_125427aa.jpg   another lanyard reason-img_0750.jpg
Dave M is offline
Old 07-29-2017 | 08:55 AM
Wobble's Avatar
SORE MEMBER
Mine is mounted just behind the throttle to my right
Wobble is offline
Old 07-29-2017 | 09:40 AM
Sydwayz's Avatar
Forum Regulator
Use a couple of zip tie sticky back mounts to test where you are thinking about mounting it, before you actually start drilling. Zip tie the actual switch to a couple places, and stretch the lanyard to see how far you can get before it pops out.
With a majority of setups having the controls to the right of the wheel, like Dave's pictures above; my recommendation is down below the wheel hub or controls about 6-8 inches, maybe even a foot if you plan to clip it to your life jacket, over your short's waistband; or short's-leg-opening like I do. Most of us never take our hand off the throttles; so that's your most common anchor point/area for the kill switch.
Sydwayz is offline
