Go Back  Offshoreonly.com > Owners Forum > Checkmate
Splashed the boat this weekend! >
Old 05-20-2002 | 04:15 PM
Checkmate283's Avatar
Default Splashed the boat this weekend!
Put the boat in the water for the first time this year and everything went well except performance is not the same as last yr! Its a 99 ZT240 with 454MPI. Last fall i was getting 66-68 with a light load. Yesterday I could only get 60-62 with light load. Was only getting 4200 -4400 rpms when i usually get 4600-4700. I did not change anything except oil,plugs, prop sharpened and the usual for winter/summer prep. I'm thinking bad gas! Any ideas??
Checkmate283 is offline
Old 05-20-2002 | 09:50 PM
HiPerf2000's Avatar
with addition to the plugs & oil every year, i usually do the cap & rotor, and fuel/water separator.......But i'll usually run the boat briefly before changing out the fuel/water seperator to catch some of the water that built up in the tank over the winter.
i also do my plug wires & sea water pump every other season.
start by changing out the separator and fill up with premium fuel and you should be ok.
Mark
HiPerf2000 is offline
Old 05-20-2002 | 10:20 PM
Tinkerer's Avatar
Probably bad gas- add some premium
Tinkerer is offline
Old 05-21-2002 | 09:48 AM
I did do the cap and rotor as well as fuel/water separator.....I will try some premium fuel on the next tank. thanks
Old 05-21-2002 | 09:56 AM
HiPerf2000's Avatar
You may want to check the fuel/water separater again.....if condensation built in the tank over the winter it may have filled the separator. You can usually just take it off, physically look at it, pour it out, and reinstall.
jeff32
04-14-2007 10:54 PM
klaw
06-27-2006 09:56 AM
Here's Johnny
05-07-2005 11:29 AM
KAAMA
09-02-2003 11:26 AM
Rick G
06-13-2003 09:43 PM
