Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Mercruiser Drive Coupling (260 Stinger) >
Old 11-06-2006 | 07:44 PM
Default Mercruiser Drive Coupling (260 Stinger)
I had a drive coupling spin this fall. I pulled the motor tonight to replace it. Im thinking of doing the other motor as well while Im at it. Anyone know of good sources for parts? Ive used Aftermarket Marine before and had good results, but Im not sure If I should use an aftermarket part in this area. I dont want to have to pull it mid summer again to replace a junk part. Anyone have any suggestions? Pulling the engine only took a couple of hours with cleanup and all. Its a little tight, but not too bad. They dont give you much room between the two motors thats for sure! Thanks Dan
HuronRiverRat is offline
Old 11-06-2006 | 10:58 PM
jeff32's Avatar
Default Re: Mercruiser Drive Coupling (260 Stinger)
I used Sierra parts for couplers and never had any trouble in 3 years with my stinger...
jeff32 is offline
ve3lt
Chris Craft
11
04-10-2008 08:09 PM
point92mach
Chris Craft
0
08-20-2007 01:01 PM
ENGINESPLUS
Chris Craft
35
01-16-2006 11:56 PM
gotime34
08-19-2005 06:44 AM
FloridianSon
10-26-2004 08:51 PM
