Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Hull tuning. >
Hull tuning.
Hull tuning.
Old 04-11-2009 | 07:40 AM
Well I believe the factory posted the Scorpion 23 @ 52 mph with a stock 330 454 @ 4400 rpm and 46 mph for the 260 hp, thats about all there is unless you add hp, shorten the drive or raise the rpm's. Is the B3 a duo prop? If it is you certainly will not need the additional prop for ventivation problems unless you raise the drive to a point you do. (Tom Z), not right now, but check back latter in the summer, I'm having a merc dealer go thru them now, they will be perfect. I will post top speed with the standard alpha 1.5 ratio drive then #s on the SS.
First I want to get the livorsi prop slip guage / gps speedo.
I will say I ve never had a scorpion 23 that was light in the bow, between the deep set standard drive height and the 454
weight, mine have always been tail heavy. (Scorpion 23), the distance between the swim platform and the water line is maybe 2-3". If you are putting in thru hull exhaust you will have to go thru the transom and thru the swimdeck. Be careful
in not going to deep, you will suck water and bend valves or to shallow as the water you are pumping out will come back when you get off the throttles. Better find the stock setup to alleviate these potential problems, though rare they were available.
540phil is offline
Old 04-11-2009 | 07:43 AM
Correction
I will say I ve never had a scorpion 23 that was HEAVY in the bow
540phil is offline
Old 04-11-2009 | 11:16 PM
My boat already has the thru hull exhaust with the silent choice diverters. The only difference is going to be that I will not be using the 3" riser spacers that were there from the factory due to the raised engine/drive height. I have new stock Merc manifolds that I will use for now (I know they dont flow worth a sht but I cant afford any others yet) I also have a set of stainless merc elbows that i will get rid of. I will get a set of flange to flange elbows, cut a flange to fit the outlet surface of the elbow. I will weld a 3" inner pipe and 4" outer pipe to the flange that mixes water with exhaust as far back as possible. I dont think i will be able to use the silent choice anymore due to the camshaft that will be in the new motor. I also am thinking about adding at least one set of flappers to the system when im done. As for the water line, i think that the water line was about 2" away from the bottom of the swim platform with the Alpha and small block. I hope my platform isnt under water with these mods. That would suk! I think ill leave the hooks in for now and see what the boat does with the new mods. Ill be happy with 60-65 mph with 400 hp. Im also looking into a hydraulic steering setup and thinking about extending the bennet trim tabs that are already on the boat. Is it possible that my 23 Scorpion LTD with thru hull exhaust came with a big block and someone just threw in a small block? Someone on here commented that the LTDs came with 454s. I would also like to post pics here but cant find out how. Can anyone help with this?
Scorpion23 is offline
Old 04-11-2009 | 11:22 PM
I know they made them with either BB or SB !!!!
Also i realy don't think its such a good idea to raise the engine up or the drive,,,leave the engine where is and get a 2 inch shorty !!!!
U raise alot of weight which isn't that smart in a single engine boat !!
But thats just me .
DareDevil is offline
Old 04-12-2009 | 04:39 PM
I already raised the drive/engine 2.5". All glassed in and ready for gel. I had to replace the transom and I cant afford a shorty so I had to make the best of what I had.
Old 04-12-2009 | 05:40 PM
Well,,lets see how it works .....i quess !!!!
Good luck ,Happy EASTERN and stay safe !!!
Old 04-12-2009 | 06:00 PM
Same to you and hope all is well.
Old 04-13-2009 | 03:44 AM
Thanks,,and let us know how it works out !!!!!!
