Go Back  Offshoreonly.com > Owners Forum > Chris Craft
first 245 ltd >
first 245 ltd
first 245 ltd
Old 06-06-2010 | 10:54 AM
Default first 245 ltd
just got the boat a couple weeks ago it in great shape,,the best part i payed 100 dollars for it,,its a big block and i have a 21 pitch prop on it but im only getting 4200 rpm and 52 mph any one shed any light on what to do to get more speed?
tw50 is offline
Old 06-16-2010 | 12:31 PM
Default Chris Craft Limited 245
What engine and outdrive do you have in your Chris Craft Limited 245?
There is a youtube video of someone who got just over 70 MPH with a modified 496 Magnum:
http://www.youtube.com/watch?v=lxoz3-8Vfrk
I have a 245 Limited I am restoring now.
I am looking for some parts from a junked Limited. Do you know where I can get one for $100 like you? LOL
Mechnologist is offline
Old 08-16-2010 | 10:52 AM
I just test drove a 245 limited with a OMC 454 king cobra drive at 5000 RPM the boat only goes 40 mPH what can be wrong???????????????????
myflytoys is offline
Old 08-16-2010 | 01:42 PM
TomZ's Avatar
MAJOR PROP SLIP!!
That's excessive. What was the trim set at?
TomZ is offline
Old 08-18-2010 | 08:48 AM
I trimmed it up to the point of cavitiation then backed it down tap. Wierd right! Do you think the boat shoud be faster the engine doesnt skip a beat. I have no idea which prop is on it. Could the speed be all prop since the fact it runs great. Please help......
Old 08-18-2010 | 08:49 AM
What if it had a bad engine coupler. I smell no rubber and i hear no wierd sounds
Old 11-28-2010 | 05:20 PM
ttttttttt
tw50 is offline
Old 12-02-2010 | 08:03 PM
how old are these boats......... and were they run in the salt chuck for any length of time
rotten strigers and ozmosed glass adds 1 ton easy
Centsless is offline
Old 12-29-2010 | 10:22 AM
I have one that I have ran for a year and a half. It is a 7.5 (Ford, That's right!) with King Cobra 1.42 drive. It ran right around 52 with the factory electronics no matter what prop. I ran a 20 at 4400-4600 rpm and a 24 at around 3600-3800 rpm (to low). After upgrading to MSD dizzy and coil it picked up to 55 with the 20 still in the 52 range with the 24 and it seemed to come out of the water much better.
The thing is a tank. From what I can find the claimed weight is 4750lbs. Most similar size more modern boats run around 3600-3800lbs. I like mine. It crushes waves and rides nice. It could stand some more speed-----so.
I have built a 521 with aluminum heads and plenty of goodies for this season. I broke the new motor in on muffs and then had to winterize it before I got it in the water. Man I can not wait until spring!
JKKJ is offline
