Go Back  Offshoreonly.com > Owners Forum > Chris Craft
thermastate or not? >
thermastate or not?
thermastate or not?
Old 04-22-2011 | 07:44 AM
Ok you guys, guess I had a bad idea. I concede defeat and will runt he stock themostate. haha.
mittens is offline
Old 04-23-2011 | 08:42 PM
Originally Posted by Stinger390X
No engine should run without a thermostat. All engines which produce horsepower need to operate at "operating temperature" for optimum performance.
In a boat the steady flow of water will cause the engine to run cooler than normal which may cause loss of power, sludged oil or fouled plugs and a host of other conditions.
In an automobile with a radiator, if an engine operates without a thermostat it might even overheat! you ask how...it's because the coolant does not stay in the radiator long enought for ambient air to cool it so you are sending hot water back into the block. In a boat you are probably using sea water which is already cool causing lower than normal engine temps.
Hope that helps you inquirey?
X2!! pulled my stuck therm out once to get home... fouled 2plugs, and ran like crap!
johnnykool6 is offline
Old 04-24-2011 | 09:47 AM
Thanks to all the info, the engines both have stock thermostat's in them now. The boat is new to me so trying to fix what the other guy screwed up lol.
tczracing is offline
