Re: A little late but better than never
1 Attachment(s)
A peek inside
3 Attachment(s)
More
1 Attachment(s)
Number 2 on the starbord side poped a head gasket. sure am glad I found out this way :rolleyes:
3 Attachment(s)
More :D
Why a gear drive for timing? I figured the harmonics from the drives would be hard on that?
Reinstalling the gear drives wouldn't be my first choice.
Looks good Russ.
Just a little side note I find it eaier to pull the trans with the motor. Alot less bending over the back of the motor getting those bolts off. you can slide it out with the drives on. But pull the drives before reinstalling them. You need to check the U-Joints anyway Good catch on the head gasket. Could of been bad. Mark |
Originally Posted by MrCIG
good catch on the head gasket. Could of been bad.Mark
They have worked perfect for 300 + hrs. What issues do they present???? Thought they were less prone to fail then chains + more accurate. |
Looks good Russ.
Just a little side note I find it eaier to pull the trans with the motor. Alot less bending over the back of the motor getting those bolts off. you can slide it out with the drives on. But pull the drives before reinstalling them. You need to check the U-Joints anyway Good catch on the head gasket. Could of been bad. Mark Did you get out on the water for a test run this weekend??? |
| All times are GMT -5. The time now is 08:46 PM. |
