A little late but better than never >
Old 05-02-2005 | 09:34 AM
RUSSSR1's Avatar
Default Re: A little late but better than never
Originally Posted by Crazyhorse
When you say bad, do you mean bad like a sunday morning hangoverheadache? Or bad like a broken leg from trying out your kid's snowboard?
Hi Dave
Hangovers arn't that bad cuz you can just pop another one and wala headache gone. Now on the other hand a busted leg from snowboarding could be a bad day
RUSSSR1 is offline
Old 05-02-2005 | 04:33 PM
MrCIG's Avatar
Charter Member#330
Originally Posted by RUSSSR1
Yes I see that Mark. That is the way I would do it next time. I do have plans to replace the u-joints. I started to have a small vib at the end of the season when turning that was not there before.
Did you get out on the water for a test run this weekend???
No I should have some Demo props this weekend from throttle up to try. I plan on testing Saturday.
Mark
MrCIG is offline
Old 05-02-2005 | 10:22 PM
Doug's Avatar
(aka) Pure Adrenaline
Think you will have her back together by the fun run in June ? I hope to be up and running by then.
Mark, have fun Saturday. I hope the weather cooperates.
Doug is offline
Old 05-02-2005 | 10:48 PM
RUSSSR1's Avatar
Yes I should be back together by early June with all the bugs if any worked out by the fun run.
RUSSSR1 is offline
Old 05-03-2005 | 06:54 AM
offshoredrillin's Avatar
Gear drives are a direct link from crank to cam, therefore they transfer harmonics from each. if a crank is a little off balance, it will transfer through the gears, as to what extent, I'm not sure, but a good way to think is, if you hold a stick out and give a little shake on one end, the harmonics will make the other end shake much more. I'm sure they are good, other wise people wouldnt use them, but in all my street motors I've always used a cloyes true roller with adjustable tabs. Send a pm to JC or Laz Mesa, They might be able to specify more details...Rob
offshoredrillin is offline
jjforbes
Ft Myers Offshore
6
07-10-2006 09:21 PM
thedonz
10-17-2005 03:12 PM
HOUSTONPROP
10-17-2003 11:35 PM
HyperBaja
07-27-2003 03:27 AM
Bill272
06-14-2002 10:34 AM
