Removing Floor >
Removing Floor
Removing Floor
Old 05-22-2005 | 04:17 PM
Panic Button's Avatar
Emerald Coast of Florida
Default Removing Floor
How big a pain in the *ss is it to remove the floor in a Cafe? One of the drains must be clogged with crap, I've had water sitting in the cabin for 2 days and it hasn't gone down any. Remove the access panel under the drivers side and can't see any way to clear it from there.
Panic Button is offline
Old 05-23-2005 | 07:42 AM
Default Re: Removing Floor
I have the floor out of my 86 cafe, it was not to had to take out. But you still can not get to the drians mybe if you take the fuel tanks out, but that is not easy good luck
Mike Baldwin is offline
Old 05-23-2005 | 09:31 AM
I got the wet/dry vac out and sucked a ton of water out. I used about 4' of 1/2" hose to snake around under the holding tank and the drain in the cabin, and pulled leaves and other trash out. Would it hurt anything to pour some drain cleaner in there? I'm thinking of the citrus kind, I really can't pull the tanks, filled them up last week...
Old 05-23-2005 | 11:49 AM
go to an industrial hvac store... maint equpt... they sell a CO2 based high pressure drain cleaner... blast out all the crap
dreamer is offline
Old 05-23-2005 | 12:57 PM
DanB's Avatar
Charter Member #71
What dreamer said
I would start behind the hatch forward of your bearth. Thats were the drain holes start. and blow to the rear of the boat. The main drain should be right at the keel in the bilge with 2 up higher on either side. If you have a wire puller try doing that first to clear the way a little. Good luck
DanB is offline
Old 05-31-2005 | 09:24 PM
I went to Lowes and picked up some 6' sections of threaded rod, cut them in 3' section and coupled them together to unclog it. It looked like 60 gallons of sludge came out after an hour finally clear water is coming out.
Old 06-04-2005 | 02:16 AM
grimmy's Avatar
yuck
grimmy is offline
Old 06-04-2005 | 07:42 AM
offshoredrillin's Avatar
At least ya got it out, nothing like a high colonic for a boat huh? Whats amazing is how that stuff gets there, its a sealed compartment...
offshoredrillin is offline
nocigarette
Magnum Marine
17
01-04-2008 05:32 PM
Prater
22
10-14-2005 11:14 AM
THEJOKER
05-12-2004 08:44 PM
HiPerf2000
9
05-07-2004 10:38 AM
Tigger
06-05-2002 08:37 AM
