TG rear seat back removal - HOW??????
Originally Posted by pm203
Bill,
Call that number I gave you.He can explain it completely.
I have no PM's or emails. . . . . .
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Originally Posted by BillR
The whole back area one piece???
I am not sure on that. Here is 2 pics that show the seat back. The seat back appears to be a seperate piece. Roger1's pics are different from what I have. His is one peice and looks it.
Now the sides (where the steps are) and the seat base are definately on unit.
The boat is an '02 (made in the summer of '01)
Any more thoughts?
If it IS one piece - I am not going to mess with it. The vinyl is in great shape - just can't get it "bright white" looking. Plus I wanted to re-do the Cig oval. Has some purple in it that has slightly faded - plus I don't care for purple.
Any more thoughts?
I just talked to the guy that I have done a ton of Cig interiors for from OK, and altho the hasn't had an '02 apart we both kinda agree they are probably the same as the older ones.
First the bolsters will have to come out to allow removal of the side panels.
Two we're sure the back seat is all one piece altho it may not look like it. And it should have some bolts into the floor under the seat cushion on the rear side of the front section on either side of the electrical panel. And altho you will have to undo the electrical panel it will slide thru the hole without undoing all the wiring.
Third it should have some bolts under the hatch into the rear of the seat, but may not be in plain site. Like near or hidden by trim pumps or something. So look close. But like was mentioned it is a huge heavy piece so have plenty of help.
Good luck.
John
Sunrise Upholstery
Originally Posted by lakeluvr
Bill,
Good luck.
John
Sunrise Upholstery
Good luck.
John
Sunrise Upholstery
Here is a picture taken from the engine compartment looking forward to the bulkhead behind the rear seat. I have circled the bolt heads in red so you will know where to look for the ones that need to be removed. John is right about being able to fit the electrical panel back through the hole that it`s mounted in without disconnecting any wires or cables. I removed mine because it needs to be redone.
Hope this helps
Roger
Ok I think I have a grasp on it now.
Got those 3 bolts in engine box, floor brackets/screws for front of seat.
Are there any bolts to be removed from the sides?
Side panels are coming off for re-do too. John, how do I measure those 4 side panels so I can get enough matching vinyl from you? Those are too big and fragile to ship.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Bill,
I should be able to get some measurements off of a Gun here to send you enought vinyl to do the side panels, so no problem.
Good luck.
John.
Good luck.
John.
