Twin Step X Dimension Question >
Old 03-20-2007 | 12:57 AM
Jeffrey's Avatar
FOUNDER and BG1
Default Twin Step X Dimension Question
If it's not too much trouble I would like to find an approximate x dimension for twin step Guns and Tigers. I am considering the Imco shorties for the Tiger.
I did measure the relative height of a regular twin step Gun against my F2 Gun and I recall that the F2 drives were mounted about two inches higher than the regular Gun. However, I do not remember how deep the drives on either boat were relative to the hull.
I'm also curious if there is a difference in the depth of the drives on a twin step Gun versus a twin step Tiger.
Jeffrey is offline
Old 03-20-2007 | 06:28 AM
offshoredrillin's Avatar
I asked the same question for my straight hull, everyone told me I would have a hard time getting on plane. I cant see much difference in our boats until we are up on plane, then the aeration would kick in...
offshoredrillin is offline
Old 03-20-2007 | 12:57 PM
HUSTLEthis's Avatar
Hey Jeffrey, I can go measure Kevin's boat if you want me to.
Tom
HUSTLEthis is offline
Old 03-20-2007 | 01:00 PM
Jeffrey's Avatar
FOUNDER and BG1
Tom
Hey Tom! That would be great. Just make sure the drives are in line with the hull (neutral position). Thanks!
Jeffrey is offline
Old 03-21-2007 | 05:15 PM
HUSTLEthis's Avatar
Ok, I finally got by the shop today and measured the depth of the drives on Kevins boat. They appear to be 3" below the bottom. He has 1" shorter Imco drives. I know he has to work on getting on plane sometimes, but as you know, his boat hauls...Hope this helps a little.
Tom
Old 03-21-2007 | 08:29 PM
Jeffrey's Avatar
FOUNDER and BG1
Tom
Thanks Tom! Just curious ... I know the 6s are surface drives but where does your bullet sit in relation to your hull? In line or just below the hull?
Jeffrey is offline
Old 03-23-2007 | 07:13 PM
HUSTLEthis's Avatar
The bunks on the Myco are right in front of the drives, but what I can see, they appear to be in line....
Tom
SDFever
Nordic
30
04-05-2008 11:43 PM
tanner
03-05-2008 11:30 AM
fastlane40
11
09-15-2007 02:17 PM
ripride1
Fountain
8
04-30-2006 11:33 PM
jryan26
Fountain
1
01-10-2006 04:58 PM
