35 Cafe' With Shorten Drives >
Old 08-20-2007 | 02:50 PM
Charter Member # 1083
Default 35 Cafe' With Shorten Drives
I have a 91 Carbon Fiber Cafe' with 700 hp engines. I'm running 30" 4 blade Bravo props. I have thought about playing around with my "X" dimension by getting either 1" or 2" shorten Bravo lowers. Has anyone tried these on a Cafe'. I referenced the fact that this is a Carbon Fiber boat because I thought it might respond different than a regular fiberglass one.
I'm also considering Boxes. If you've had any experience with these I would also be interested in how they turned out.
Thanks in advance,
Bob
If it's not a thunder run.............than you're just burnen fuel!!!
BOB ONEIL is offline
Old 08-20-2007 | 09:11 PM
Jamie B.'s Avatar
Warped & Twisted Member
Smile
Just curious, what speeds are you currently running ?
My prior '91 Carbon Fiber Cafe with about 575 per side and 25p 3 bladed Bravo's saw 84-86mph on Gaffrig Speedo ( non GPS ) with nose cones.
Jamie B. is offline
Old 08-22-2007 | 08:12 AM
I'm not really sure. My GPS was stolen and I know the speedo is not that accurate. I think it runs around 85 + ?, from what others next to me say. I should invest in a new GPS before I get too crazy with modifications.
Old 08-22-2007 | 10:36 AM
Croozin2's Avatar
84 - 86 with 25 3-blades? What RPM were you turning those motors? Had to be pretty high.
Croozin2 is offline
Old 08-22-2007 | 10:41 AM
CigDaze's Avatar
With 1.5 ratio drives it would have to be damn near 6000. With 1.36's it would be closer to 5200-5300. But he did say it was with a speedo not a GPS, so....
CigDaze is offline
Old 08-23-2007 | 10:01 AM
Jamie B.'s Avatar
Smile
Correct, right about 5200, 1.36's. 85-86 mph was light fuel and load in salt water. Fresh water would see 83-84 consistantly. Derebery Marine SC 600's. Gaffrig speedo only verification.
Jamie B. is offline
Old 08-23-2007 | 10:07 AM
Jamie B.'s Avatar
Smile
FWIW - this is the boat / my old boat I'm referring to. The Dereberry 600's are no longer in it though.
http://www.offshoreonlyclassifieds.c...o17182-en.html
Jamie B. is offline
Old 09-04-2007 | 02:26 PM
I remember that boat from when I was looking for mine. Other than mine being red and gray, they're identical.
klaw
4
12-10-2004 09:09 PM
Shah Mat
6
08-31-2004 02:16 PM
Dean Ferry
11-27-2002 08:09 AM
kook
9
04-02-2002 05:33 PM
