Engine Spacing >
Engine Spacing
Engine Spacing
Old 09-20-2008 | 02:01 AM
Default Engine Spacing
Are the Stringers on a 28 the same with small and big block? am looking at a 28 that had twin 350s TRS Boat currently powerless Would like to put twin 454s in . Want to make sure that they will fit this hull Also Ive seen some that have these motors Will they fit with a 72 trans?Or will they be to far ahead Motors will be spiced up 420s Thanks
brian becker is offline
Old 09-28-2008 | 06:50 PM
The stringers are the same. The big blocks will be very tight. Small blocks are tight. What year is the boat? The earlier ones that had the Merc Trans have a little shorter engine compartment and they moved the firewall foreward about 6 inches to make room for the b&w's.
You may want to either consider a different hull or going to small blocks. I've heard the 28's are a little tail heavy with TRS and big blocks. I know mine with small blocks has a great balance.
Dangerous Dave is offline
Old 09-28-2008 | 09:31 PM
The closest you can go with BB i think is 34 centerline.
So it should fit ,but i would consider to stick Bravos on the baby saves weight and gains speed.
With a small boat like a 28 footer Bravos will not give you any problems the TRS i think is way to much for a 28 with max 550 HP ?????!!!!!!!
Closing the Transom and cutting out for Bravos is around 1000 bucks at the most, so well worth it.
DareDevil is offline
Old 09-30-2008 | 02:12 AM
Default early boat
the boat had smallblocks with merc trans What hp can a bravo 1 take without pushing its limits with healthy smallblocks
Nauti By Nature
Do It Yourself, Boating on a Budget
21
02-20-2008 01:23 PM
knollwoodworker
10-16-2007 06:34 AM
gripit
Cigarette
0
11-04-2004 09:32 AM
Pat McPherson
12
11-29-2003 11:22 PM
