Bullet question...dead batteries >
Old 10-20-2008 | 08:32 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
here you go
just hook battery charger or jumper battery to these terminals and hit switch on dash you may have to go to jump start moode on charger
Attached Thumbnails Bullet question...dead batteries-csc_0012-medium-copy.jpg
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 10-20-2008 | 09:17 AM
lakeluvr's Avatar
www.sunriseuph.com
Thanks a ton, the pic looks great, but altho I don't have a pic of mine...yet...that doesn't look anything like my configuration. Will find out today. Thanks again. John
lakeluvr is offline
Old 10-20-2008 | 01:12 PM
lakeluvr's Avatar
www.sunriseuph.com
Tried a variety of connections with and without using the switch, all to no avail. Haven't tried any kind of jumper yet. But here is a pic of mine. Thanks everyone for your input. John
lakeluvr is offline
Old 10-20-2008 | 03:48 PM
lakeluvr's Avatar
www.sunriseuph.com
Default Whoopee
OK, here is the deal. After lots of trial and error all with no success, I began to think maybe the electric motor was frozen or bad. Anyway, I called a friend at a local marina and he was able to stop by for a look. He hooked it up just like I had been doing and said it was trying to run, but maybe my charger wasn't big enough, it was only a 4 Amp model. So I went and got my 10 Amp/start model he hooked it up and the hatch came right up.
So, for future reference, the blue wire is "up", so hook the positive from the charger up to it, and the negative up to the black wire for ground and it should work.
Thanks to all for everyone's input and suggestions.
John
lakeluvr is offline
Old 01-14-2009 | 06:36 PM
Clay Washington's Avatar
Originally Posted by lakeluvr
The unit is under the seat on the port side. It appears to have two sets of solenoids. The red wire is on the right side, there is a blue wire on one and a green wire on the other. So are you saying that this unit controls the drives and tabs as well?? Thanks for you input.
As a general rule of thumb, the blue (sky) is up and the green (grass) is down.
Clay Washington is offline
Old 10-14-2013 | 05:49 PM
wayne272's Avatar
Have a similar problem, without the dead batteries. When I hit the dash switch, in either direction I get a clicking sound from the solenoid that is mounted in the engine compartment.( it has the 2 positives from the batteries along with other wires connected to it) I can jump the red on the pump bracket (the pump is under the rear bench) to either the blue(up) or green (down) and it will raise and lower the hatch. I replaced the up solenoid because one of the studs stripped and still nothing. I removed and wirewheeled all ring terminals to no avail. I figure the dash switch must be good if its activating the solenoid. What does that solenoid in the engine compartment have to do with hatch operation?
wayne272 is offline
Old 10-15-2013 | 04:31 PM
wayne272's Avatar
Got it. Looked at the wiring diagram and it turned out to be the circuit breaker on the panel just inside the cabin over the storage locker. It must have accidentally been shut off going into the cabin.
wayne272 is offline
Old 10-16-2013 | 08:52 AM
carter38's Avatar
Done that before hit a couple of them and had lots of stuff dead. Flipped a switch and fixed easy fix.
carter38 is offline
Old 10-18-2013 | 08:23 PM
VP of the tickfaw200
The wiring on a bullet or at least mine is crazy. Pulled out 2500' of it!
caseyh is offline
96f350psd
13
01-18-2009 07:14 AM
Dago Racing
17
01-18-2009 07:10 AM
chrisf
5
01-18-2009 06:59 AM
tomswift
18
04-20-2007 09:09 PM
RUSSSR1
Cigarette
16
04-20-2004 07:41 AM
